![]() | Home > Maintenance & Mods (L322) > 4.4 V8 Petrol rocker cover gaskets |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626
After six months of owning the full fat, it was time to do the rocker cover gaskets as they had developed a slight leak.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Your engine innards look fine, that is the normal look for vehicles with a few years under their belt and a few miles on them, it does not, and indeed I would argue should not, be removed... You will cause damage to the engine by trying to get it off...
Dear Pete,
Oil flush is basically paint thinners, it will strip off some of the gunk and suspend it in oil and take it around all the oil ways and force it into the big ends, little ends etc, IMHO this does more harm than good... just use a good quality oil and a genuine or branded filter and it will be fine... |
Thanks Pete, this makes perfect sense.
Modern fully synthetic oil will still be good at 20,000+ miles but they recommend replacing at manufactures intervals because they sell more...
Duly noted, Pete
Great improvement, they will look good fitted... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
i watched a wheeler dealer recently and they made sure they didnt powder coat the inside of rocker covers cos the heat build up over time could dis-lodge the powder coating and damage the engine.. ... - .- -.
Indeed
That's true and thanks for the heads up, Stan. We've actually intentionally powder coated the gasket channels and not the undersides, which remained for the most part bead blasted. But the color is so matching Last edited by vs322 on 12th May 2020 11:29am. Edited 1 time in total |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
Looking good. |
Thanks For the record: You can use glass (bead) OR very fine carborundum grit at low pressure. True about the magnesium alloy. |
Thanks for the reply.
Worth changing the rubber grommets too, if you haven't gotten them already, of course. |
| All times are GMT |
