Home > Technical (L405) > What’s this cross headed part called? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
I think it's called the cross headed part.....
12th May 2020 8:38pm |
Thanks
12th May 2020 8:42pm |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 76 |
Don’t know about JLR, but to most OEMs, it would simply be a clip. |
12th May 2020 8:48pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
Ask for the fixing clip that holds the cover for the engine bay fusebox Ryan... |
12th May 2020 8:59pm |
If you find yourself at a complete dead end? I could post a couple up to you... Would rather not step on anyones toe's on here at Duckworths etc so please try sponsor first sir... |
12th May 2020 9:03pm |
Beach Member Since: 11 Jul 2015 Location: Bristol Posts: 54 |
LR024316 i think this is the part number |
12th May 2020 9:04pm |
LR024316 isn't quite the same, it is a two part clip, the one above is a single part with a thread on the bottom.. Pete
12th May 2020 9:21pm |
these are the ones in the engine bay either side of rear cowl or over the headlight access panel. This is where i look up part numbers
12th May 2020 9:56pm |
Sorry Pete but that part number is correct sir... Ryan’s picture only shows one half of the clip that holds that panel on👍 |
12th May 2020 10:14pm |
Excellent... doesn't take much to confuse me these days...
12th May 2020 10:35pm |
i just bought some myself |
12th May 2020 10:38pm |
Thanks very much all 👍🏻 |
12th May 2020 10:47pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
Got these off eBay eBay Item No. 192690438547. Only a couple of quid and did the job |
12th May 2020 10:50pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 378 |
In my 2016, there are 14 of these in the engine compartment. I have replaced about 5. They are really designed poorly. They strip out fairly easy. |
14th May 2020 2:33am |
