![]() | Home > Maintenance & Mods (L322) > I think my Landrover adventure is coming to an end |
pk7976 Member Since: 09 Mar 2017 Location: Kingston Upon Hull Posts: 33 ![]() ![]() ![]() |
Driving home from work today 2007 TDV8 i got less than a mile from home and as i pulled up to a red light I noticed coolant steaming off from the car along with the check coolant warning, No sign of any overheating on the gauge so continued to drive it home.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
I feel it stripped down then replace and see how you get on |
That’s what I am concerned about, a hose should not pop off unless of a catastrophic failure however now it’s in bits and I can see that the thermostat has been leaking I am in a quandary as to do I replace the thermostat housing before rebuilding it only to find the engines scrap effectively writing the car off.
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
Could it be that the hose has been taken off before and the clip was not put back on? I cant see any marks on the hose to indicate that it has been forced through the spring clip.You say that the thermostat has been leaking which could have been coming from the hose. How long have you had the car. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
"Curiosity killed the cat"....no point sitting in your rocking chair years down the line wondering "I wonder if a new thermostat would have cured that Vintage collectable L322 I had years ago?".
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
Not to get your hopes up too quickly, but that's the wrong hose clip that is fitted. It should be the same as the other two shown in the picture.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I don’t think that is the wrong clip, as I had the mother of all jobs refitting them all when I replaced my alternator and they all were the same type as the one that has blown off. Got - 2017 SDV8 Autobiography in Loire Blue
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Agree Alan, the clip is the correct one, and yes they are a b |
Had the car three years now and cooling wise it’s been fine (lots of other silly problems) the thermostat appears to have only been weeping from a joint not this hose. A guy at work has commented that the hose appears to be oily and that could have contaminated it etc which I guess is possible I was surprised how “squishy” it was. I have contacted a dealer and I can get a thermostat and a top hose so will order them and get them fitted whilst replacing the spring clips with jubilees. |
Good lad! |
Best of luck with it, theres plenty of threads on here too on how to bleed the system if your not sure, did mine a couple of times for varying reasons and was always quite straightforward. |
Slow progress this weekend as I found another hose that I may as well change whilst i have it all in pieces however its all stripped and the old thermostat has been removed ready for replacement. Will order the parts and aim to get it back together next weekend. |
That's the spirit! |
