![]() | Home > Maintenance & Mods (L405) > Windscreen washer |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
mine are more of a fine mist than the older spray type so i doubt if a needle would clear the holes...an air hose should blow the curd out..
| Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 93
Yes agree , mist
WM download link is in the wiki.. |
Can’t find it Stan, but thanks, I’ve found loads of other things! |
tis a labyrinth of info in there.. |
| Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428
Is that with or without lemon Stan ? 2003 Range Rover Vogue TD6 |
someone is sharp today Brian... |
Indeed, I've just cut myself on my razor sharp wit - pass the plaster please |
i best not mention your spelling mistake in the other thread... |
Shows you're paying attention in the cheep seats. |
| roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203
I use a single strand of wire from an old bicycle brake cable or similar if you have one which are very thin but rigid madam |
