|  | Home > Maintenance & Mods (L322) > Rear Diff options |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Have you checked the diff for backlash and worn bearings, I've had diffs full of mud before and it's usually just the bearings that suffer, the backlash and wear of the gears wasn't an issue... Doubt there are aftermarket ones, not a big enough seller... Not sure on compatibility between Land Rover species..! Good luck Pete
|  16th May 2020 11:40am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | I'm surprised that the diff isn't an e-diff as I thought all 4.2 SC were fitted with e-diffs.
|  16th May 2020 8:03pm |
| sigmaes Member Since: 02 Jun 2017 Location: FL Posts: 2      | thanks for the info, I was really hoping that the only difference between the RR and LR3 diff's was just the output flange.
|  17th May 2020 2:01pm |
| Posting Rules
