Home > Technical (L322) > L322 front gateway control module issue
Tswitch
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Hi I wonder if anyone can help. I was using sdd recently to clear a fault issue with the suspension (all sorted) but during the sdd session I noticed there was a recommendation for audio software update. This was run. Now my entire head unit is non functioning. I have gone over all details I can think of within sdd to try to correct but no luck at all. I can see within the sdd that I need to update the modules but it will not allow me to carry out. Keep getting gateway error Confused
All else with car is ok apart from the dead unit. Anyone assist?
Post #553480 11th May 2020 7:35pm
What platform are you using to read/control SDD..? Pete
-Click here for Thread-
Post #553483 11th May 2020 7:45pm
Tswitch
V154 I think
Jlr mongoose pro
Post #553484 11th May 2020 8:08pm
Don't know it myself, maybe a software error, will it not roll back..? Pete
Post #553503 11th May 2020 10:27pm
Tswitch
No tried that, won’t roll back. In fact won’t communicate with the module at all
Post #553512 11th May 2020 10:57pm
Not read of anyone on here using it so don't hold your breath...!!! Pete
Post #553513 11th May 2020 10:58pm
the_ferret82
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
i have used SDD a few times myself 159 is the current version,
i have not see the issue you have described before. but based on what your saying it sounds like there is a communication issue in the cars network might be worth running some network connectivity tests and seeing what fault codes exist. i suppect your issue is not down to the audio update you did.
i assume you had a charger connected to the car when doing the update and the battery didn't die?
Post #553673 13th May 2020 9:53am
GraemeS
Australia
Have you disconnected the battery for 10 secs then tried to communicate with the module afterwards?
Post #553676 13th May 2020 10:10am
Tswitch
Yes tried that and run connectivity tests. Looks like it could be gateway problem.
Ran sdd in engineering mode today. Looks for sure gateway.
Have it on order.
Let’s wait and see if it solves the issue
Post #554014 15th May 2020 8:25pm
the_ferret82
i would suspect its a connector not the module
Post #554017 15th May 2020 8:50pm
