![]() | Home > Maintenance & Mods (L322) > Suspension bushes |
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
you haven't said which bushes? |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
There aren’t too many which would poly bush, personally wouldn’t bother. It’s not a sports car or a hardcore off road machine....
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
I had a quick look under the front of the car and thought the rear lower arm bush looked rotted. I've read that this seems to need replacing quite often? Just thought I'd look at something more durable if that's the case but didn't want the ride to feel harsh. I'm still learning about this car and if standard bushes last OK that's the way I'll go. Some times when I brake hard I can hear a slight 'thunk'. Thanks Kev. |
The outer lower rear arm bush is a rose joint so again not really one you would want to poly. Inners possibly.
| All times are GMT |
