![]() | Home > Maintenance & Mods (L322) > How to secure the bike on the official Land Rover bike rack |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
I use surfboard straps. Just loop them around the frame(s) and tyres and then tighten.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Hey mate.
NO photos available I'm afraid but I wrap the strap thru the bike frame, around the "cow" bars, through the wheels and then through the main vertical upright and secure. Never had an issue even with 3 bikes. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8126 ![]() ![]() ![]() |
Strap down each tube of the bike against the rubber pad
What kind of straps did you use bud?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1427 ![]() ![]() ![]() |
What I did was to get bungees (the LR accessory rack comes with one long strap only) of different lengths and hook them over the frame and into the holes in the base of the rack. Then to stop the wheels moving about and to hold the bicycles steady I would have shorter bungees around the bottom of the wheels and hooked on to that base or maybe the lashing eye on the right side. In some places I used bubble wrap to stop the bicycles rubbing together. After that the light board was attached to the outer bicycle with cable tie loops and rope. Quite a long process, not recommended in a cloud of midges at the end of a long day in the hills, but it did work and was secure and steady. Only Range Rovers since 1988 |
Thanks buddy. I shall experiment
I used a number of different straps - initially some Thule ones, but the metal clips were a pain, then burgees but didn't really get on with them, then progressed onto velcro tape - basically double sided velcro - wrapped round a couple of times & job done.
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 134 ![]() ![]() ![]() |
I use straps like this [https://www.ebay.co.uk/i/292755313482] to hold the frame against the rubber pad on the carrier, then a couple of bungees down near the pedals and around the carrier to stop the bike swaying forwards and backwards.
