![]() | Home > Maintenance & Mods (L322) > Noisy Brembos... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8741 ![]() ![]() ![]() |
According to the maintenance record the front discs and pads were changed less than 20,000 miles ago, no make was stipulated..
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
I've heard good things about EBC Green and my mechanic mate who works on mine for me (only few I trust!) has them on his Sport. I will be fitting them next time round. He fitted Mintex coated discs on rear and Pagid pads (FYI).
But but but, the green clashes terribly with the Ipanema Sand.... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Re-spray the car? ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
JLR only is my advice Pete... Thats not to say EBC don't work! As i have not used them...
Valuable advice Craig ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
robw54 Member Since: 24 Jan 2020 Location: Sheffield Posts: 3 ![]() ![]() ![]() |
I recently swapped my worn discs which had started squealing when hot/low speed which had had new pads a year before - not sure of make. as I didn't do them. I then replaced for bremo discs/pads at front myself, all in was £150 ish for parts and new sensor. No noise at all now and much less fade. |
Less than £40 a front set on euro for brembo - throw them on and see if it improves. Cheap fix.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
Brembo don't make brake pads.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 952 ![]() ![]() ![]() |
I like to support Birtish made where I can - so will carry on buying EBC Green |
Ferodo and Jurid are OEM to JLR... |
Thanks guys, sure I read somewhere Jurid were OE JLR.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Yep.... I wrote that
Cheers.. And yes they do seem elusive... I see they now do a low dust pad for an extra £160... ![]() ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
