![]() | Home > Maintenance & Mods (L322) > Noisy Brembos... |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 925 ![]() ![]() ![]() |
this is the biggest "Brake Pad" player in the market
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8752 ![]() ![]() ![]() |
Tbh the OE on different years varies, as said I’ve bought LR OE pads for the 4.4 ‘12 and they were Jurid, but in the same vein the rears on my ‘16 are stamped LR and TRW. IMHO I’ve not had many “bad” sets of pads I’m running a set of Pagid pads on my D4 at the mo and they are fine. There is nothing that can't be fixed with a hammer😜😜
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3837 ![]() ![]() ![]() |
I have put Pagid pads on my 2011, and they are fine, but in honesty, at the speed I drive these days, I could have probably made a set out of the cardboard box they came in., the 6 pot pads are so big.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I replaced my pads a couple of weeks ago with Ferodo both front and back. They were and still are totally silent. Naturally give it a good clean and I apply copper grease on non disc contact surfaces... |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1320 ![]() ![]() ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8679 ![]() ![]() ![]() |
It's best to use brake grease that is designed for alloy calipers, copperslip can cause galvanic or electrolytic (can never remember which, or maybe both!!) corrosion and damage the calipers... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Nah....Old school is best. Once my big jar of Texaco copper grease is finished I'll take a look again as to what is there now in the market. Its been fine for me, my father and my late grand father...Besides what electrical contact is there between the metals? |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
OEM seriously (otherwise, you'll forever be wishing you'd just bit the bullet, gone OEM and forgotten about it) |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252 ![]() ![]() |
I'm another ebc green stuff user, 20k and faultless with so little dust Remember:- amateurs built the ark
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 75 ![]() ![]() |
As an fyi I was cheap and fitted twr pads to my 6 pot brembos and they do squeel rather often.. it could also be related to the aftermarket rotor I'm not sure. Anyway I just live with it... I find it's only a major problem when trying to stalk people 😂
There is no particular reason why TRW pads have to squeal. I would refit them and use some nice copper grease on the metal to metal parts. My cheap ferodo ones are perfect, upon second fit 😂 |
I can't work it out. I've had them out a couple times.. blown dust out greased all the right parts with bendix ceramic brake grease which made it worse for a while after I re did it last time would you believe.. all fitment parts and springs are brand new
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
TRW manufacture brake calipers and other brake system components, but worked with / bought brake pads from the brake pad specialists like Ferodo, Jurid, Pagid etc. TRW would supply the assembly of caliper and pads direct to Land Rover. Paul,
Copper grease is for use on steel calipers, there is an aluminium grease for use on the Brembos, the wrong grease is one reason the pins corrode in. Bluegreygreen, it sounds like you are glazing your pads, if you have performance items on your car you have to use them as intended now and again, a few decent brake applications should sort it out... The noise I had was not squeaking, it was just a hot brake noise, but excessive, some brakes just do it, hence my original question.... the pads were worn and the discs damaged by heat which was difficult to spot between the spokes of the wheels it had on... ![]() You can see a pad impression on one, this is where you keep your feet on the brakes after stopping from a decent speed and heating the brakes, it causes a hot spot on the disc and deposits resin from the pad onto a local area of the disc, do this too often and the discs will suffer. You shouldn't sit with your foot on the brakes when they are hot, use the handbrake.. New discs and pads, the correct pad bedding in procedure to cure the resins in the pads and they are quiet again... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
