![]() | Home > Maintenance & Mods (L322) > Dual Battery Installation |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Just completed a dual battery installation on my 2012 4.4 TDV8 VSE using the electrical harness supplied by:
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Nice easy job |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4346 ![]() ![]() ![]() |
Is this so you have more juice to start it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
What are you using the 2nd battery for? I would think the guage of wire is much to light to carry any significant load. The loom can be easily lifted up and out of the battery area and run above the fuse box, it is now very vunrable if the battery moves as its not secured down.. A much more heavy duty instal can be made with a metre of decent cable and a voltage sensing relay capable of handling the current.
voltage sensing relay rated at 100A |
@Joe90,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8110 ![]() ![]() ![]() |
It's not voltage sensing - it's switched via the ignition
You have two things: the "voltage sensing relay" (as Alistair says) which clicks in when the ignition comes on, and a 100 amp fuse on the main cable to the battery to prevent catastrophe |
Almost..... the relay isn't a true voltage sensing one - its triggered by the ignition - that's the independent connection that goes to the mini fuse - when that terminal gets power of roughly 12v it triggers the relay making a connection across the 2 main terminals
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
A VSR isn't expensive. Nor a 100a fuse.
There's a fuse in the kit linked in the original post - but not visible in the pictures |
VSR - depends on what you want. If it's sole purpose is to boost starting capacity, then you don't want a VSR - as it will actively prevent the second battery helping if the main battery is below 12.7v....... |
The thin wires on the install in question would surely melt under starting load if the cranking battery was flat? I doubt very much that the relay from that kit is anything more than a standard 12v relay rated at 100a, it's just switched via ignition and not by voltage increase.
Many thanks for everyone's knowledgeable input on the dual battery system that I installed.
