Home > Maintenance & Mods (L322) > Painting l322 exhaust, Hammerite Paint ok ?
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all,
Read a few posts on here regarding painting their exhaust, some say high temp others say normal is fine
Does anyone know if the standard Hammerite? I have some Hammerite Smooth Metal Paint.
Or do I actually need a high-temperature paint for the back box ?
thanks alot 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #554988 23rd May 2020 11:34am
What's the worst that can happen ?
I'm fairly sure it's not flammable, so worst case it cracks & peels off ? Then is maybe harder to get the rest off & paint with something else ?
Given you already have the paint, I'd be inclined to just give it a try and live with any consequences.
Edited to add -
On second thoughts, having just looked on eBay - a tin of black BBQ spray paint is a tenner - I'd be more inclined to buy that....
Post #554990 23rd May 2020 12:00pm
99% of paints will be fine with the temp the rear box gets to... Thumbs Up Pete
Post #554993 23rd May 2020 12:15pm
b348xyx
thanks for the replys Smile will get this done next week then. when its not so windy ! 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #554997 23rd May 2020 12:51pm
darrenm
I just sprayed mine Matt black it’s still looking good 18 months on
Post #555004 23rd May 2020 1:29pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I used some high temp mat black but as others have said it doesnt really get very hot so Im sure any old stuff will do. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #555005 23rd May 2020 1:39pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
High temp matt black spray works great. Surface preparation needed is minimal, just wash with soapy water, use the green (rough) side of a scotch brite sponge while you're at it. Rinse and let it dry.
You can use a piece of cardboard to protect areas you don't want sprayed.
Post #555059 24th May 2020 5:49am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Used Hammerite smooth satin black on both of ours, one was done nearly a year ago and is still fine. Make sure you prep well and get all the old loose stuff off and feather all of the edges with wet and dry. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #555062 24th May 2020 7:54am
Bradders
Just to give you some encouragement.......
Quick wash with soapy water, dried with kitchen roll, rubbed over with a wire brush and two coats of high temp matt black paint applied by hand.
Ideal job for a bank holiday Monday Thumbs Up Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #555066 24th May 2020 8:24am
Did mine with black BBQ paint. It’s all in the prep. The surface must be very clean and free of dirt and dust. There is nothing that can't be fixed with a hammer😜😜
Post #555072 24th May 2020 9:30am
