![]() | Home > Technical (L322) > TDV8 Vogue 58 plate |
| gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163
I'd charge the battery first. I've had doors unlock but no dashlights at all with a flat battery. |
| Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132
Giles
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Fault codes read? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Dees the park brake light illuminate? |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
When you put the key in the lock I’m sure that you can hear the steering lock disengage? There is nothing that can't be fixed with a hammer😜😜
No nothing Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
The steering lock is disengaged even with the key out. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
It sounds like something has been unplugged, have you been round all the cubbies and ECU compartments toncheck that all the plugs are home.
Can't do that because it will not power up Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Does it power up the dash with the little button on the kick panel, next to the OBD port? |
Mikey
Now, with that button pressed, does the car start? |
No unfortunately not Current cars
Time to break out the multimeter, and begin testing the ignition fuses and feeds, I think
| All times are GMT |
