Home > Technical (L322) > 6HP26 intermittent fault after filter, sleeve and fluid |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
I would try removing the multi-connector plug and then reconnecting it, to make sure that it’s seated properly. They are quite fussy.
24th May 2020 8:20pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
This is who I was hoping especially for a comment from - so do you mean just unplugged the cable from the outside of the box and plug it back in? As in a 5 minute job? And check that gap is around 3mm?
24th May 2020 10:33pm |
Yes, exactly.
25th May 2020 12:10am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Of course it is in a really easy place to get at and to see exactly what is going on .
25th May 2020 12:32am |
Hi guys - took the plug off and it had some oil on it must have been from the change cleaned it and reseated it and so far so good but it was intermittent from cold so not sure yet. Interestingly that gap in the pic is more like 7mm but it feels solid??? Current stable:
25th May 2020 8:02pm |
