![]() | Home > My Range Rover > 1st attempt at detailing |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Nice one, well done. |
davidkm Member Since: 18 Jul 2018 Location: Kent Posts: 9 ![]() ![]() ![]() |
They're on the list (the nuts). |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1040 ![]() ![]() |
Looking good, if you didn't get a sealant on it after the polish and wax then give it a coat well worth it |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1515 ![]() ![]() ![]() |
That looks the business, |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Nicely done, looks great - you picked the best car there is for towing a caravan. |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287 ![]() ![]() |
Sealant?. Normally I just polish then wax which gives great results. Can you give us some pointers....... Hunt for a L405 is on. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Great job, beautiful colour.
I suggest these 2
I went for the full Meguiar's shareholder option and the Black Plastic Restorer is on order to complete the set. I decided against the Meguiar's clay bar because the Bilt Hamber had excellent reviews and only required water for lubrication. First time I've used a clay bar so I'm no expert, but it certainly did the job. The Meguiar's Compound did a great job removing a couple of small surface scratches. I also used it on my wife's MX5 Mk IV to remove some scratches. That earned me some brownie points!
Yep that's pretty much all you need.
By heck!
I'll put you on the waiting list, Rich |
The wifes car, I havnt actually given it a proper detail for months but when I do its washed, polished waxed n sealed. I did give it a quick snow foam 5 days or so ago so today it got a very quick once over with home made quick detailer spray on the body work and my own diy plastic restorer.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
I use a G3 Pro 7191 deep clean clay mitt. Very easy with plenty of lube. |
