Home > Technical (L322) > 2008 Dash removal
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
2008 Dash removal
In the process of stripping the dash out of my TDV8 to repace the ignition switch. I have the two end panels off and all of the torqs along the top. I have removed the facia above the top glove box and removed then three torqs there however the dash still appears to be fixed in on the nearside and holding the passenger airbag in too.
Can someone tell me what I am missing please? Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #555261 25th May 2020 4:55pm
Mikey
Its a little fiddly, but you can just remove the centre trim, column shrouds and lower kick panels, and access the switch that way Thumbs Up
Post #555268 25th May 2020 5:43pm
JPJ64
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Did you realease the screws under the centre air vent?
Post #555277 25th May 2020 7:07pm
Mikey
Both centre console side panels off
Drivers sill cover, bonnet handle surround and pedal cover off
Undo 5/6 lower screws securing lower facia and pull outwards gently
Release 4 clips for centre of dash and ease past lower facia
Gives access to 2 screws holding barrel onto the plastic panel, which in turn in secured by 3 screws. 2 are easy to get to, the 3rd not so much
Once free, it can be eased out under the touchscreen trim, giving access to barrel and switch Thumbs Up
Post #555286 25th May 2020 7:46pm
Simon_CSK
So it can be got at from the bottom? Current cars
Range Rover CSK
Discovery 3 HSE
Post #555292 25th May 2020 8:04pm
Mikey
No, need to work through the column shroud and space from the centre panel
Officially, top of the dash, IPC and lower shroud should be completely removed, but Censored that Laughing
Post #555309 25th May 2020 9:35pm
Simon_CSK
Yes Current cars
Range Rover CSK
Discovery 3 HSE
Post #555340 26th May 2020 12:00pm
Simon_CSK
Mikey
I take it the sill cover is pried off as I can see no fixings to undo. Current cars
Range Rover CSK
Discovery 3 HSE
Post #555383 26th May 2020 5:58pm
Mikey
Yes, held in place with 4 plastic clips Thumbs Up
Post #555389 26th May 2020 6:17pm
Simon_CSK
Thanks easier than I thought.
Trim is easy to break and expensive to replace so appreciate the help.
Tomorrow will strip out the rest and see if I can get the switch removed. Current cars
Range Rover CSK
Discovery 3 HSE
Post #555406 26th May 2020 7:19pm
p38arover
Australia
While it's apart, replace the bulbs in the upper footwell lights. I was never able to remove the lights as per the handbook instructions. Use quality bulbs or LEDs. I replaced mine with Chinese LEDs and they have gone into flicker mode (as have most of the others I replaced with LEDs from the eBay LED kit). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #555456 27th May 2020 1:29am
Simon_CSK
Mikey
got there in the end. A few variations and I needed to lift the top section of the dash to get one of the speedo trims out but essentially I am ready for the new switch. As soon as it arrives I will know if my new car goes or not. Shocked fingers crossed.
Can the switch be tested now that it is out with a multi meter? Current cars
Range Rover CSK
Discovery 3 HSE
Post #555497 27th May 2020 1:05pm
Simon_CSK
This is the offending switch note the logo on the top of it.
It is a BMW switch and certainly cheaper than getting it from Land Rover Current cars
Range Rover CSK
Discovery 3 HSE
Post #555551 27th May 2020 8:07pm
