![]() | Home > Technical (L322) > Vacuum pump, brakes operation? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
L322 2007 Super Charged
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Just looked at the workshop manual and there is quite a detailed description of how the system works in the chapter "Power Brake Actuation"
I have read the manual several times previously, and again today.
Sorry missed the sensor bit..
The reason Im asking these questions is that under normal driving conditions the brakes are great.
One line in the manual "the electric vacuum pump supplements the main vacuum supply from the engine manifold"
There is stacks of vacuum available from the inlet manifold
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Surely with a supercharged or turbo'd engine the inlet manifold has a positive pressure rather then a vacuum as per normally aspirated engine? BMW i3 Electric Car
"Surely with a supercharged or turbo engine the inlet manifold has a positive pressure rather then a vacuum as per normally aspirated engine?"
I would disagree, in a throttle closed situation a normally aspirated engine creates maximum vacuum i.e. when braking just when you need it, a turbo or supercharged engine will have very little vacuum on the inlet to the turbo / supercharger, there's no airflow, theyre effectively open to atmosphere or have I got that wrong? A venturi system would only work with airflow and of course causes a restriction in the airflow which is exactly what we want to avoid by turboing or supercharging an engine. BMW i3 Electric Car
"A venturi system would only work with airflow and of course causes a restriction in the airflow which is exactly what we want to avoid by turboing or supercharging an engine."
Then go for it,m remove the vacuum pump and connect onto your alternative vacuum source. Supercharged I dont know enough of the details, turbo I would say youre wrong, the inlet side of the turbo is open to atmosphere pretty much. BMW i3 Electric Car
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 711 ![]() ![]() ![]() |
Supercharged engines definitely don't generate as much vacuum at the inlet manifold as a normally aspirated engine.
Erm your talking at crossed purposes........did you read the OP, your confusing the intent of the OP Nobody is removing anything and Im not asking questions about turbo charged engines Specifically the query is as to when and why the VP would operate? Due to the fact that I dont actually see it as being in operation most of the time, the query is as to what triggers it and how it is getting a signal to do so. On a duty cycle basis it would not have the capacity to operate continuously, unlike a TDV8 vacuum pump which is belt driven. |
