Home > Technical (L322) > L322 TD6 Intermittent Non-starting
Page 2 of 3 <123>
tpeat12
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Okay, so this morning's update:
I turned on the ignition and the engine fire up. Turned off the engine, waited a few seconds, turned the ignition but no start. I measured voltage across battery terminals while cranking and it was approximately 8.9 V. Based on this, I thought the issue must be battery related. Next step, I hooked up jump leads to my other car, waited five minutes, but still no start. The measured voltage across the battery terminals while cranking was around 9.5 V.
Am I right in thinking that this points towards fuel/injector issues?
Post #555975 31st May 2020 9:08am
dingg1
Go to any motor factors, have them test your battery, once its confirmed Censored part with the price of a new one and I bet your problems will disappear.
Stop pratting about with jump leads and worrying about injectors or fuel issues, do the simple stuff first
Post #555981 31st May 2020 10:01am
tpeat12
Fair enough. I've ordered a Yuasa HSB020 battery from Halfords and will get it installed this afternoon.
Post #555983 31st May 2020 10:58am
Fox889
A little direct maybe, but I think he got the message! Rolling with laughter  2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #555986 31st May 2020 11:11am
mjdronfield
I’d say if it runs fine after the easy start, prob injectors.
If it fires on easy start, then stops, fuel pump?
Have you ruled out the fuel pumps? AA man pulled pipe off fuel filter under bonnet and when I put ignition on, fuel squirted out, so we knew pumps were good. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #556000 31st May 2020 12:21pm
mjdronfield
Ignore my post above.... was replying to your query on the previous page....not read the posts after...oops...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #556001 31st May 2020 12:23pm
tpeat12
So, new battery fitted - no start; same symptoms as before.
Back to pratting around? Wink
Post #556009 31st May 2020 1:57pm
Fox889
ok, well that's discounted the battery so tick that off the list.
If all this non starting comes from you jump starting the RR when the battery went flat, that's where we've got to start from.
Assuming the previous was telling the truth about it being fine then we have to look at what 'you've done'.
Fuel pump seems a strong point or how about the diesel filter being totally blocked?
Electrical wise, then one thought could be the ignition switch?
I'm fumbling in the dark like a teenager on a date at the local Roxie cinema hoping to push the right button.
I'm thinking out loud now whether that confuses the issue I don't know, just trying to help. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #556010 31st May 2020 2:07pm
dingg1
Well your not pratting about with jump leads anymore, so it's ruled out the battery issue, next check is glow plugs
Good luck
Post #556046 31st May 2020 7:49pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
I had the same issue on my TD6. Would start fine one minute, then just spin over and not fire the next time. It did turn out to be the secondary-fuel pump, they're easy to do, just inside a panel under the N/S/R floor, you should see cross head screw if you pop underneath the car then remove the small plastic panel, you will smell of diesel once complete. If you want to check it, next time it does it get someone to lean underneath with lump of wood and bash it while turning the key, it usually shocks them into life. (How I proved mine) Mr. Green
Post #556069 31st May 2020 9:54pm
mjdronfield
That’s the one I said to wack.... easier if you take the plastic cover off.... though mine wasn’t intermittent. Just stopped working.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #556074 31st May 2020 10:19pm
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Another vote for the secondary fuel pump here, mine had similar symptoms.
What does your code reader say - low fuel pressure while starting?
Post #556093 1st Jun 2020 7:04am
tpeat12
Cheers guys,
plugged in an old BMW code scanner and picked up '1260 - Pre-supply pressure monitoring' and '09F6 - rail pressure monitoring on engine start'.
Given that it's pulling up an issue with the pre-supply pressure, am I right in thinking that this does point towards the secondary low-pressure fuel pump?
Post #556096 1st Jun 2020 8:19am
JohnK
My code reader said exactly the same and it was the rear pump.
Reasonably cheap and easy to fix.
Just for clarification - the pump under the car just forward of the rear wheel arch
Post #556097 1st Jun 2020 8:31am
tpeat12
Cheers John. Will try the spanner trick to see if it gets it going but certainly looks like the most likely cause now.
Post #556098 1st Jun 2020 8:43am
Page 2 of 3 <123>
