![]() | Home > Technical (L322) > Transmission Failsafe 2004 L322 4.4 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 936 ![]() ![]() ![]() |
change the radiator for a new one, anything will do, the bottom 8 rows collapse and the auto oil cooler temp levels get very high, whatever you do don't buy a Land Rover radiator ( as the same thing will happen again in 10 years time )
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
Don't waste money on another battery, buy an IID tool and start checking things out, go through the live values and see what you can find...
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Smather glad to see you made it here from facebook, have a look round the site and then find RRphil's posts and have a read.
His is not the same fault as yours, if it's doing it whilst cold then it's different issues... it may very well need a new rad etc but he has to diagnose the problem first... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
If you are going to flush yourself I've 6 litres of the trans fluid on ebay. Will help with the pennies and I'm ijust south of the M4 M5 interchange.
smather Member Since: 01 Jun 2020 Location: Gloucestershire Posts: 5 ![]() ![]() ![]() |
Thank you! |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Since you are in Gloucester, you should really bring it to L322 professionals: CMS LAnd Rover in Stroud : Cotswold Motoring Services http://www.cotswoldmotoringservices.co.uk/aboutus.html http://www.cotswoldmotoringservices.co.uk/contactmap.html Craig Hennell, in Dursley: 16 Brunel Rd, Dursley GL11 5DH Téléphone : 07950 021102 l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
Hi all, am going to CMS on the 15th to have codes checked and transmission fluid replaced and sump off and check for any metal filings in the oil etc. Fingers crossed this will be the solution I need and not a gearbox! |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
If it all goes wrong (hopefully it won’t) you could do a lot worse than contacting these chaps |
What the update Mate, was it only the XYZ then?
Hi there, sorry for the delay - after numerous calls and different advice and almost selling it I decided to start simple. Luckily I have a great local garage that look after me and my various cars and are usually willing to give most things a go that I throw at them! Started by doing the transmission fluid change and checking for any shavings - fortunately there was little debris stuck to the magnets and everything looked good - no more than you would expect on a regular change. The transmission fluid was lower than it should have been so a necessary job done. Started the car once that was complete and still getting the same problem. Mechanic agreed that it seemed to be electrical rather than mechanical / gearbox failing. He also had the gut feeling I had about the xyz switch and got quotes for recon units. I asked him if he would be happy to drill out the rivets on the existing one and have a look inside and clean it up if necessary and adjust the contacts if they looked like they needed it. He was happy to give it a go and there was a build up of muck inside and the contacts were worn and not making clean contact so he adjusted them. Had it dropped back today and excitedly jumped in and put the key in - straight away ping and transmission failsafe message.... thought great what a waste of time and money. I then took the key out, back in and boom 💥 it started! Took it for a drive, smooth gear change and pick up through all gears and had 0 troubles which is not something I have had for months. Thinking it was certainly not the gearbox that was shot as the local independent Land Rover garage said with a £3k quote to fix.... I think the failsafe message may just be a warning that the xyz has been fiddled with so may not be perfectly adjust but at least I can drive and have a smile back on my face!
very good news to hear, well done - and saved £390 quid if you had to get a new one |
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
By coincidence, my 2004 V8 is at Birch Motors with the same symptoms as Smather’s Range Rover. I’ll report back on this thread to let you know what Birch find.
Birch are a lot more focussed on L322's and BMW X5 gearboxes thats for sure
