Home > Maintenance & Mods (L322) > Squeak when I turn left
vikehp
France 2011 Range Rover Vogue TDV8 Santorini Black
Hi everyone,
First of all sorry for my rough English Embarassed
I have a squeaking problem when I turn the steering wheel to the left.
It occurs mainly at low speed (3 to 20 mph) and only on the left.
Here is the famous noise:
https://www.youtube.com/watch?v=OutuvO7ZVrQ
Front brake pads and rear disc and pads were changed 3 months ago.
Any idea about this noise?
Thanks in advance Bow down
Post #556361 3rd Jun 2020 2:44pm
lower suspension arm? ... - .- -.
Post #556363 3rd Jun 2020 2:51pm
What Stan said and A few things to check, wheel bearing, they can squeal when in the early stage of failing... disc stone shield is bent and touches when turning, this is a common fault... brake pads can do it as well if the caliper is sticking... drive shaft CV joint can do it as well, check the boot to see if it's split...
Any garage should be able to find it for you with a jack up and wheel off etc... Thumbs Up Pete
-Click here for Thread-
Post #556365 3rd Jun 2020 2:54pm
vikehp
Thank you for your feedback Smile 2011 Range Rover Vogue 4.4 TDV8
Post #556367 3rd Jun 2020 3:03pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Anti squeal shims in the calipers with the pads? coat the rear face of the pad and the shim with copper grease or ceramic grease to stick them together. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #556370 3rd Jun 2020 3:38pm
vikehp
I will try this solution to start.
I specify that it starts to happen after several miles... 2011 Range Rover Vogue 4.4 TDV8
Post #556373 3rd Jun 2020 4:20pm
AJGalaxy2012
I had a very similar thing occurred on my TDV8, I think it was as the caliper warmed up, clearances changed and squeal started. Many moons ago my dad had a Morris Marina that did it terribly and it took while to discorver copper grease on the back of the pad solved the problem. BMW i3 Electric Car
Post #556378 3rd Jun 2020 4:41pm
vikehp
Let's hope that the copper grease was the beginning of a solution 2011 Range Rover Vogue 4.4 TDV8
Post #556385 3rd Jun 2020 5:30pm
Do not use copperslip on yours, you have aluminium calipers and it is not good for them, use the correct aluminium grease.. Thumbs Up Pete
Post #556391 3rd Jun 2020 6:26pm
I use ceratec on my pads. Either Pagid or Textsr do it. Always seems to work ok. There is nothing that can't be fixed with a hammer😜😜
Post #556392 3rd Jun 2020 6:29pm
vikehp
Thanks Thumbs Up 2011 Range Rover Vogue 4.4 TDV8
Post #556501 4th Jun 2020 2:49pm
