![]() | Home > Off Topic > Old diesel v new diesel and French heating oil. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Some information here:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Interesting article.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
The red stuff is maybe good for heating, we do the "super" for stock reasons and cleaner burning, but even my tractor is doing better on normal diesel as on the red stuff, so would surely not put it in the range rover. Apart from that IF they catch you (and yes customs do check regularly) you will be paying heavily!! |
725browning Member Since: 02 Sep 2019 Location: Northampton Posts: 73 ![]() ![]() ![]() |
You are correct in saying that 32 second will run a derv but it is not advisable. Here we burn 28 and 35sec oil. France uses 32 sec which is close to diesel but they all lack certain elements made by manufacturers like lubrizol to lube bores etc. Heating oil can clog inlet and exhaust valves and though certain engines will run on it they can be more noisy and smoke. If a standard pressure jet oil boiler burner suffers with poor fuel pressure and incorrect air induction it will smoke, tar the combustion chamber walls and quickly blocks the blast head and will eventually go into lockout. It is a simple case of new nozzle, a clean out and fresh set up using an analyser and pressure gauge on the fuel pump. If you consider using heating oil you would have to use additives to help with lubrication and also alter the sulphur contents. Mind you, if you just want to run a dumper truck or any crude engine then slap a load of 35sec in and ffs don't breathe it in |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1272 ![]() ![]() |
Ok. Thankyou guys...
