Home > Wheels & Tyres > Spare wheel question.
I’ve just taken the spare wheel out of the wheel well and the polystyrene under it to get in the full sized wheel.
Is there anything which goes underneath a full sized spare wheel something to space it off the battery cable maybe. To my eye the batt cable seems to be squished between the wheel and the floor...... There is nothing that can't be fixed with a hammer😜😜
Post #556515 4th Jun 2020 3:59pm
Mine looks like this -
The cable to the Anderson connector (& the crumbs) are mine.
I think there might be a piece of carpet missing - it kind of looks like there should be something over the battery
Post #556519 4th Jun 2020 4:35pm
Alistair, That’s what mine looks like when I e taken the poly out 👍🏻
I’ve had a google and there are 2 part numbers for a polystyrene insulator. The first Is for the bottom of the wheel well lr033233 when there is a space saver fitted, which is the one I’ve got. It’s like a big doughnut. There is also LR033234 (also big doughnut) but thinner for a full sized wheel.. This should go in the bottom of the wheel well under the wheel and tyre. There is nothing that can't be fixed with a hammer😜😜
Post #556523 4th Jun 2020 5:09pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Now that needs a hoover Sir
Post #556525 4th Jun 2020 5:20pm
It's been vac'd since that photo - I do the interior every couple of years Whistle
Though with this lock down it's had 2 washes this year already Shocked
Post #556555 4th Jun 2020 8:46pm
For completeness......
The thinner packer arrived and even with that the 275/45/21 doesn’t fit. I suspect a smaller “full size” wheel and tyre might.....
So it looks like Alistairs boot is about right.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #558648 22nd Jun 2020 7:16pm
Sandyt
Careful it might change colour as you wash the paint of once a year is more than enough
Post #558649 22nd Jun 2020 7:19pm
@Sandy - I do normally wash it seasonally - so it's not been spoiled too much during lockdown Laughing
@NMJ - I nearly ordered one, thanks for posting back, glad I didn't Very Happy - not sure which wheels it's for then as mine came with 255/20's - I fitted the 22's
Post #558650 22nd Jun 2020 7:29pm
Bingo_123
quick question about spare wheel size. i am running 255/55/20 and dont have a spare wheel.
do i have to buy same size/type wheel or can i buy the space saver spare wheel.
i have seen few in 195/70/20 size.
or basically is there a spacesaver spare wheel available for 255/55/20 ?
please advise
Post #562505 24th Jul 2020 11:48am
I guess no reason why it can’t be a space saver..... but why ?
I’ve really never seen the point in a car that was designed to accommodate a full sized spare. I get it if there isn’t the space, hence the need to save some..... But that’s not the case.
I’ve only ever had a few punctures, yet they always seem to occur a long way from home, on a Sunday, with a long journey left. So I like a proper spare in the FFRR.
Post #562509 24th Jul 2020 11:58am
Bingo_123
there is no preference for spacesaver, i would personally prefer a full size spare.
just wanted to know if there is a spacesaver size available too, just to see if i have 2 options.
otherwise will stick to my search for a full size spare.
thanks
Post #562511 24th Jul 2020 12:24pm
bishbosh10
please advise
As long as your rolling radius is the same on the axle you'll be OK. the two sizers in your post are close enough to be OK (<1% difference by my quick calcs)
Oh and the tyre used is speed / load rated etc. etc..... Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #562520 24th Jul 2020 2:00pm
Bingo_123
Thanks
Post #562523 24th Jul 2020 2:29pm
