![]() | Home > Technical (L322) > DPF red warning |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
I wouldn't
aggraa Member Since: 16 Apr 2018 Location: diss Posts: 33 ![]() ![]() |
Thanks for the responses. Currently I am in Bulgaria been stuck here because of lockdown. We had stricter rules here than in UK so couldnt travel anywhere since early March.
ah ok so you you are at home - good thought you were stranded!
Hi Greg.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
look at my threads ref this. It was a cracked inlet manifold only discoverable by HIGH pressure smoke test. could be a tiny crack in a pipe, not visible to the eye.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
How did you reset with an iid tool, I thought when red, they needed a forced regen? |
Yes I agree to invest in an IID.
I only managed it once, before the soot level got to 28.5 (forced regeneration cut off). I did an oil change as fuel in oil level was reading 12 (Cut off is 7!!)
so can anyone answer my question? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
If it were me:
Hi. I have just got back from the local garage , I asked them to do check the fault codes and do a forced regen.
DPFs are more resilient that some say. A dealer will tell you to buy a new one. But it may be clean-able.
I had Terraclean clear my DPF for £200. above a level of 28.5g the LR equipment will NOT be able to force regeneration.
Thanks for the replies, I am gonna take the forum advice and not drive the car anymore.
