![]() | Home > Technical (L322) > Injector leak back - too much fuel in return line? |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1041 ![]() ![]() |
Most of the fuel is returned to the fuel tank its normal |
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
This is coming from the disconnected return line, that would normally be connected to the top of the injectors, I havent traced it but assume its going back to the tank, hence the concern over the amount of fuel coming the "wrong way" |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I Believe you are supposed to clamp these return lines when doing the test otherwise fuel spills. |
