Home > In Car Electronics (L322) > 2007 Bluetooth; echo echo echooooo
Kent_newbie
HI everyone,
MY 2007 Vogue L322 gives a horrible echo to the person on the other end of the line. I've googled and searched here, and see others have had similar, but for the life of me I can't find that anyone's discovered a solution.
Is that still the case?!
Thanks!
Tony
Post #557266 11th Jun 2020 7:48am
Weegie
Try turning down the volume on your phone a little. John
GAP iiD BT-Sold
Post #557276 11th Jun 2020 9:40am
do you have the same problem with a different phone? ... - .- -.
Post #557278 11th Jun 2020 9:48am
Kent_newbie
Yes I do - both my wife's phone and mine do it, suggesting it's car related?
Post #557280 11th Jun 2020 10:00am
Kent_newbie
So I looked at turning down my phone, but there's no control over that when it's linked to BT (Samsung S10).
I turned down the volume on the radio, apparently it helped the caller at the other end but of course then struggled to hear myself.
Seems like there's no real known cure?
Post #558249 19th Jun 2020 12:20pm
done a search on the forum and it could be,
the FF microphone so you might have to replace it,
padding out the rear of the microphone with foam
or, a faulty bluetooth unit...moisture in the cubby??? ... - .- -.
Post #558250 19th Jun 2020 12:31pm
Kent_newbie
The cubby seems particularly fine - I did have a good look. Interestingly from searching around it seems that it's common to many, rather than a specific problem.
I'll investigate the mic itself. I feel a bit impotent with it; there's not a lot to change, certainly in settings and similar
Post #558255 19th Jun 2020 2:42pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Not something I would know but does a 2007 have the upgraded mic and would it help any body have an idea on that, changed the mic in mine having done the bluetooth upgrade thing.
Post #558313 20th Jun 2020 12:15am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
I had this! I changed the Bluetooth module and the echo disappeared! 2014 vogue se
Post #560693 8th Jul 2020 7:33pm
