Home > Technical (L322) > IIDTool Ecu update
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
IIDTool Ecu update
Hey there enthusiasts Bow down
I had to connect my IIDTool today to change TPM Settings. While doing so I did run a complete ECU scann and at the end I found lots of updates available on allmost all ECU's. So...where and how can I get this updates then?
Has one of you pros any expierence on this matter?
Thanks in advance for showing me the (right) way to become happy again. Whistle
Post #552828 5th May 2020 6:33pm
MarianaWestminster
If you email Patrick at GAP diagnostics he will be able to check to see if the update is available for your vehicle.
I've just had Patrick sort me an update for the ADCM for £25.
Post #552846 5th May 2020 8:28pm
PeteT80
If it ain’t broke don’t fix it.
Unless you have a specific problem, then the general advice is to leave the ECU software well alone.
Post #552848 5th May 2020 8:52pm
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
MarianaWestminster, I'm also interested about ADCM module update. Did you got it done? Was it any good?
Can't find any information about this update.
Can you feel any difference after this update at all?
Regards
Post #557347 11th Jun 2020 6:51pm
DrRob
I would not fiddle with it but ask Pat Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557352 11th Jun 2020 7:54pm
MarianaWestminster
Hi,
Yes i got the adcm update from Pat.
No difference what so ever unfortunately.
The adaptive dynamic suspension isn't fit for purpose.
Post #557359 11th Jun 2020 9:02pm
kokamagi
Thanks for the info.
Sad, that there's no information on what exactly would any updates change/improve. Rolling Eyes
Post #557375 11th Jun 2020 10:16pm
What don't you like about it..? Pete
-Click here for Thread-
Post #557380 11th Jun 2020 11:39pm
MarianaWestminster
Its rock solid Haylands.
Feels like the dampers are made of solid steel.
Every bump and pothole results in more of my fillings falling out.
I've driven a few now and none are as comfortable as my old pre facelift TDV8. (Non adaptive)
The spiel in the brochure about it being the best ride Range Rover has to offer is in my opinion downright lies.
Post #557950 16th Jun 2020 10:39pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Interesting. I always thought mine was a bit too soft if anything. Still a nice ride but no confidence in bends. Changing my front struts though so hopefully it will, firm up a little. 2011 4.4tdv8 Vogue
Baltic Blue
Post #557951 16th Jun 2020 11:06pm
I would describe mine as on the firm side of normal but it doesn't feel rock solid, nowhere near as boat like as my last and stays pretty flat through bends...
It wouldn't be too hard to fit non adaptive earlier shocks if you prefer them...!
Gaz, yours sound like they need replacing, mine is flat through bends and handles very well for 2.7 tons..! Pete
Post #557955 16th Jun 2020 11:47pm
Gazcw
Think you are right. The oil inside the bag indicated they were on their way out. 2011 4.4tdv8 Vogue
Baltic Blue
Post #557959 17th Jun 2020 12:08am
MarianaWestminster
I did plan to fit non cvd shocks Haylands as I feel that would be the solution for me however I've started looking at supercharged L322s so might wait and do the swap on whatever I buy.
There is a non RR alternative on my mind though.. have to see what happens.
Post #557967 17th Jun 2020 7:25am
Have fun shopping, if you get a S/C maybe it will be better than you current one... Thumbs Up Pete
Post #557979 17th Jun 2020 8:59am
MarianaWestminster
That's my hope Haylands but having driven a few other CVD equipped L322s (2 of them being supercharged) I won't be holding my breath.
Post #557996 17th Jun 2020 11:26am
