Home > Maintenance & Mods (L322) > 4.4 tdv8 inlet pipe seal part no.
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Anyone know the part number for the seal that goes on the pipe that clips on to the throttle body?
Post #557117 9th Jun 2020 11:05pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
If you mean the green seal that sits inside the plastic piece that slides over the throttle body then form what I understand, this is not available on it's own, you have to buy a complete part including the pipe. Seems ridiculous as this part will lose it's ability to seal properly over the years, more so if the part is taken off from time to time to clean the throttle butterfly. 2011 TDV8 Vogue SE
Post #557130 10th Jun 2020 8:13am
DrRob
Sounds like a challenge for someone to find a source for that seal. I bet with enough digging it can be bought on its own... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557132 10th Jun 2020 8:20am
JNC
Need to check the size but the part number is similar
https://www.kmotorshop.com/article-detail/...0-31316347
Post #557134 10th Jun 2020 8:28am
dennij
This seal is missing the lip that the original seal has, it's easy to remove and check, just make sure you put it back in the same way it came out as I suspect the lip presses against the throttle body as pressure builds up. Place it the wrong way and it would allow the pressure to pass by causing an air leak. I'm doing this from memory so I'd advise you check just in case I'm talking out of my backside Laughing 2011 TDV8 Vogue SE
Post #557136 10th Jun 2020 8:50am
GraemeS
Australia
4 of these used as inlet manifold to head gaskets on a 2L engine so very likely to be much too small.
Post #557138 10th Jun 2020 9:06am
Baltic Blue
If anyone can supply an old one as a template sample, it might be worth a chat with this place ??
If they would do an order for 20 or so , perhaps Martin would sell them on via the forum shop ??
It says on their website they will make from “one off’s to thousands .
Post #557141 10th Jun 2020 9:42am
DrRob
Mike - that is a bloody brilliant idea!! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557142 10th Jun 2020 9:52am
dennij
Sounds like a good idea, although probably better to use a new seal as the template. I imagine there are a few of us on here that would look to buy the seal if it could be made 2011 TDV8 Vogue SE
Post #557143 10th Jun 2020 9:53am
Baltic Blue
I would definitely take a couple.
It’s the only thing stopping me stripping mine down to give it a good clean out.
Post #557146 10th Jun 2020 9:57am
kevinp
Go on Mike, look what is waiting for you!!!
Post #557439 12th Jun 2020 2:49pm
Baltic Blue
Big question Kevin,.... is it running any better since you cleaned it out ??
Post #557442 12th Jun 2020 2:59pm
DrRob
I’m like Mike, wanting to do it but can’t decide when to do it Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557457 12th Jun 2020 5:23pm
kevinp
Mike.
To be honest Mike, not really. It might be a bit smoother on pick up. The throttle butterfly was absolutely caked though along with the MAP sensor. If you wonder if yours need doing just take the MAP sensor out and have a look how contaminated it is. Cheers Kev.
Post #557497 12th Jun 2020 9:47pm
Baltic Blue
I do that every time I do an oil and filter change (every 6 months irrespective of mileage ).
Post #557550 13th Jun 2020 2:55pm
