Home > Maintenance & Mods (L322) > A new noise, any ideas
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I noticed a single metallic click sort of noise as I was coasting very slowly to a stop and very lightly touched the brakes. It can be replicated easily. I initially thought the pads on one wheel clicked as they grabbed but am now unsure as I can feel the click through the gear selector. When the brakes are applied does a solenoid or switch activate or deactivate something in the gearbox, should I be worried? 2003 TD6 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #557632 14th Jun 2020 6:47am
There is a solenoid on the gear selector. It activates when you push the brake and allows the gear knob to be put into park, or more correctly prevents it from being put into park without your foot on the brake. There is nothing that can't be fixed with a hammer😜😜
Post #557635 14th Jun 2020 7:13am
wayneg
That must be it, strange I have never been aware of it before. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #557637 14th Jun 2020 7:29am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Re: A new noise, any ideas
This is normal.
Although not very loud a noise, It can be felt through the gear selector at very slow speed or when stationary when brakes are applied and when brake pedal is released.
You will also notice that you cannot select D from N while stationary or very slowly moving, without applying the brakes even slightly. When the car is moving at some speed though, you can freely select back and forth between D, N and D again.
You would have noticed early on if you were used to resting your hand on the selector from years of driving a manual shift...
Post #557682 14th Jun 2020 1:56pm
