Home > Maintenance & Mods (L322) > Special Land Rover Dealer Suspension Calibration?
Shinner23
United States 2011 Range Rover HSE 5.0 V8 Santorini Black
Is there a special calibration a Land Rover dealer performs that is any different than the IIDTool's guided calibration? I have some front suspension sagging issues. My local mechanic says it's valve block related, but recommended a calibration at the dealer. Before I go through that...is that step needed?
The suspension sags even after I did the IIDtool guided calibration, fwiw.
Post #557841 15th Jun 2020 9:37pm
One (or both) of your front airbags has probably developed a leak. Lots of @ 2011 cars on the forum having this at the moment, seems to be about the time they go.... .
Post #557847 15th Jun 2020 10:01pm
As Joe says, you will have a leak somewhere, and no the dealers can't do any more than your IID can to calibrate the suspension... Pete
Post #557848 15th Jun 2020 10:07pm
Shinner23
Thanks to you both. Maybe it is the valve block as the mechanic thought it may be.
Post #557853 15th Jun 2020 10:30pm
