Home > Technical (L322) > Let me down big style today.
Captain Slog
United Kingdom 2005 Range Rover Vogue Td6 Java Black
2005 FFRR Diesel 83,300 miles regularly serviced.
On my way to have some lunch today on a dual carriageway @70MPH when all of a sudden 'Ping' 'Trans Failsafe Prog' appears on the dash display. Limped to a stop, engine off, wait a while, start engine, no message, engage drive but nothing, no drive at all in auto or manual select. Luckily I have breakdown cover so was able to get the car brought home at least.
I thought the trans failsafe was a mode that let you carry on to your destination (even though slowly) but I have no forward drive at all.
This has come at a bad time for me, I've already replaced the turbo and fuel pump and two new tyres. This new problem might tip me over the edge enough to make me want to sell, I love the car but it's costing me a shed load to own.
Is this problem likely to be a major gearbox fault? The recovery company (AA) disconnected the battery for 10min to re-boot the systems but this had no effect.
If this is a major gearbox problem can anyone point me to the guy on here who re-builds auto boxes.
_________________
Currrent: 2005 FF Range Rover L322 Vogue TD6
Gone: 1999 Range Rover P38 HSE TD6
Gone: 1985 Land Rover 90 SWB diesel
Post #55716 20th Mar 2011 5:20pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I don't know exactly what your symptoms are likely to suggest but would advise at least it is plugged in to a Landrover diagnostics before you go any further.
I spent no small amount on my box to avoid exactly your scenario.. more so as I didn't want it to let us down abroad on our main holidays. I too feel the pain of the continious service costs.. I did the Turbo myself if I hadn't I'd definately be well over the edge by now.
There was a chap on the Rangerover.net who was rebuilding ZF boxes up in the north east I think RRPhil. Has yours got the ZF or GM box? I'd guess GM?
Have you had the front prop recall done?
Could also be a failed CV joint. Both of these can be quickly elimnated with half an hour with the jack. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #55717 20th Mar 2011 5:37pm
Captain Slog
Hi
Thanks for the speedy reply
elpeede wrote:
I don't know exactly what your symptoms are likely to suggest but would advise at least it is plugged in to a Land Rover diagnostics before you go any further.
I'm ringing my local trusted independent RR repair shop tomorrow.
I don't know, mine has the BMW engine
Yes
I hope so
_________________
Post #55728 20th Mar 2011 7:31pm
Captain Slog
If this turns out to be terminal can anyone recommend a good company who can supply a re-con auto box?
Martyn
_________________
Post #55804 21st Mar 2011 8:32am
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
martyn, as said RRPhil takes these, ZF anyway gearboxes apart and rebuilds them for a hobby he only charges you for the parts, last quote he gave for a complete gearbox rebuild was around 600 ££££`s which is bloody good. why not give him a try.
good luck my friend. ONE LIFE LIVE IT
Post #55805 21st Mar 2011 8:39am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
from what i rememeber RRPhil only rebuild the ZF gearboxes, in the TD6 diesel it is a GM gearbox not ZF. Not sure if he fixs the GM box
Good Luck!
Matt
Post #55807 21st Mar 2011 8:54am
elpeede
For a replacement box Ashcrofts autos (google will find them) 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #55831 21st Mar 2011 12:28pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
when you limped, did you actually drive, or was it rolling out??
I think it its our drive shafts,, have they been replaced
Post #55850 21st Mar 2011 2:01pm
Captain Slog
The power gradually diminished from 100% when the message first appeared to 0% over about 3/4 of a mile. I did not want to stop immediately due to the hazardous traffic conditions on the dual carriageway but in the end I was forced to do so due to not having any more drive. It just sat there, if you blip the throttle when the gearbox was in 'D' the car did not move one inch.
Anyway it's at the repair place now so I should have a diagnosis soon, fingers crossed it's not to expensive but I doubt it with my luck lately.
_________________
Post #55885 21st Mar 2011 9:05pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Local to Derbyshire is
Mister gearbox in Sheffield, and E j Rose in Mansfield
Both are excellent
Post #55920 21st Mar 2011 11:56pm
Captain Slog
Right
Got the car back today. Now I'm £1,900 lighter.
The torque converter had gone t**s up so a re-con box was fitted. I also have to return to the repair place after a further 1000 miles for a partial gearbox oil change (another £150) otherwise the 12 month guarantee will be void.
Censored Big Cry Big Cry Big Cry Big Cry Censored
_________________
Post #56699 25th Mar 2011 8:16pm
ouch.. Sad ... - .- -.
Post #56702 25th Mar 2011 8:22pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Feel your pain.... Shocked My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #56704 25th Mar 2011 8:52pm
Pauld
Who did the work?
Post #56721 25th Mar 2011 11:05pm
Captain Slog
Pauld wrote:
Who did the work?
Cavendish Motors of Chesterfield, an independent Landrover repair centre who I trust. They are my regular garage for servicing ETC. They price matched the best quote I received from other gearbox specialists.
_________________
Post #56723 25th Mar 2011 11:31pm
