Home > Technical (L322) > 4.4 tdv8 coolant pipe parts
coopss
Evening! Not having much luck finding parts online.
Looking around the engine bay today and saw a weeping coolant pipe Sad any ideas where I can find the part number:
 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #558415 20th Jun 2020 9:30pm
rjff
The part you show comes as one piece from the suppliers. It has the juunction piece to the left with the two small pipes off and the large pipe on the left. It also has connectors to each. Cost is about £80 from Duckworths. Speak to Rob, he should be able to identify. If I can find the receipt I'll post the part number tomorrow if it's on there.
Try taking off the whole assmebly and cleaning it up, replacing the hose clip with a suitable alternative. Take care of the small connections, they will break Crying or Very sad
Bit in the Wiki about MAP cleaning and also search for hose leaks.
https://www.fullfatrr.com/forum/topic48780.html
Check the top rad connection piece is not damaged, probably unlikelyand you may be able to find a suitable hose replacement from the internetty thing when you have the dimensions. Cheers
Richard
Gap IIDBT
Post #558419 20th Jun 2020 10:56pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
This depending on vin.
LR029140 2011 4.4tdv8 Vogue
Baltic Blue
Post #558420 20th Jun 2020 11:00pm
Gazcw
https://www.fullfatrr.com/forum/topic48509...roken+pipe 2011 4.4tdv8 Vogue
Baltic Blue
Post #558421 20th Jun 2020 11:02pm
DrRob
As above, a one piece item Thumbs Up
Good to see I’m not the only one with preventative maintenance OCD Bow down Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558433 21st Jun 2020 8:29am
coopss
Indeed! Last thing I need is this blowing and taking the engine out. All the chords are wet so must be failing inside 1995 4.6 v8, green/tan (long gone)
Post #558440 21st Jun 2020 9:02am
coopss
Might be worth doing the radiator while they’re at it - is that a big job?
I always try to use genuine parts where feasible, or oem quality. Where is ‘Nissan’ radiators on the quality scale? 1995 4.6 v8, green/tan (long gone)
Post #558491 21st Jun 2020 4:44pm
coopss
Update - found the part was replaced 20k ago with the genuine part listed above (LR029140).
Will take it off and inspect. 1995 4.6 v8, green/tan (long gone)
Post #558585 22nd Jun 2020 12:00pm
