Home > Technical (L405) > Battery "failed" Drop Test
pld118
TDv6 sailed through MOT yesterday (expected) Thumbs Up
The MOT tester advised that whilst not part of the MOT, the battery failed a drop test (the low battery warning was on the dash when I arrived anyway). Tester advised the battery should be replaced.
Like many, the car hasn't been used much during the past 3 months. I can use the CTEK smart charger, should that deal with any issues and sort the matter out?
Car does have RAC cover that includes battery replacement, although not sure how that would work because the car has never failed to start despite the low battery warning?
Thoughts welcome.
Thanks.
Post #558446 21st Jun 2020 10:21am
Can you drop test a battery whilst it's still connected ?
I always thought it was a bench test kind of thing.
Would be an admirable effort if he removed the spare to get to the battery......
Post #558452 21st Jun 2020 11:02am
a drop test normally indicates a faulty cell so a replacement might be needed Ryan....
the test sould be done with the battery terminals off so that the vehicle electronics arnt damaged.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #558461 21st Jun 2020 1:23pm
Phil.
The CTeK should give you an indication of the battery’s health dependent on the model. Mines an old one but has a series of lights that provides an assessment of the condition after it’s been connected overnight. I’d stick it on charge and see if it fails again soon. In the current circumstances it’s more than likely to be undercharged.
I keep mine connected to a solar charger at the moment just to keep it topped up otherwise the battery light would soon come on. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #558466 21st Jun 2020 1:38pm
pld118
Thanks for the replies all Thumbs Up
Funnily enough, the spare wheel was out of the wheel well and sitting on the boot floor so access to the battery would have been easy (had the spare out to clean the wheel well the day before)... the manager did say they were all very impressed with the condition of the car in every nook and cranny so maybe they did access the battery in the well! Mr. Green
CTEK is only a few months old, an MS 5.0, seems like a good piece of kit and because of it, no worries the battery is going to die any time soon because when the CTEK‘s connected for a few hours, the low battery warning goes off...
I’ll take a new battery if the RAC breakdown covers it Wink
Meantime, out comes the CTEK and I’ll use my recently purchased Multimeter to check the battery too Thumbs Up
Post #558467 21st Jun 2020 2:35pm
Phil.
If it helps mine sits at about 12.5V when unused with the solar charger connected. MY23 D350 HSE
Post #558469 21st Jun 2020 2:46pm
pld118
Thanks Phil 👍🏻
Post #558472 21st Jun 2020 2:59pm
Why would an MOT tester be drop testing your battery?
Anyway, bung it on the ctek overnight and see if it shows a green battery at the end.
It does work, I tried to charge someone’s “iffy” battery with my msx10 and it showed an orange light. We tried the recon setting and it still came up as fault.
Don’t know if the recon string works with AGM, will have to research....... But if it’s still the original battery it hasn’t done too badly. There is nothing that can't be fixed with a hammer😜😜
Post #558475 21st Jun 2020 3:54pm
pld118
The MOT tester was drop testing the battery to try and sell me a new one, they were also kind enough to put a replacement quote of £211 on the invoice Laughing
Post #558490 21st Jun 2020 4:40pm
pld118
Just put the main battery (located in the boot/ spare wheel well) on CTEK charge overnight. When switching on the CTEK, it simply indicated that the main battery is now on charge.
I’ve successfully used the CTEK a few times during lockdown although previously put it on charge via the positive and negative engine bay mounts. Might it make a difference now I’ve put it on charge from the boot/ wheel well (i.e is that “the proper way” to charge it)?
Also, because the car’s tucked up in the garage overnight with the upper tailgate nearest the garage door it means I can’t leave the upper tailgate open, so I’ve ran the CTEK cable from the boot/ wheel well and out of a (left ajar) back door to be able to plug in into an extension cable, meaning the back door’s ajar... is there a slicker way to do it? Embarassed
Thanks
Post #558511 21st Jun 2020 7:55pm
CS
If you have towing electrics then the adaptor available from the Forum Shop is ideal, I got one for when my car was locked down, all fine. Only Range Rovers since 1988
Post #558520 21st Jun 2020 8:36pm
pld118
It’s got the factory deployable towbar but never having used it, wouldn’t know if it has towing electrics or not? Embarassed
Post #558522 21st Jun 2020 8:44pm
Phil.
From experience it makes little difference if you charge the battery directly or using the terminals under the bonnet. I charge directly most of the time. MY23 D350 HSE
Post #558551 21st Jun 2020 10:31pm
If it’s got the bar. It will have the electrics.
Should be a 13pin I reckon.
The “shop” sells the relevant plug to connect it.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #558558 21st Jun 2020 11:12pm
Deployable has 13 pin electrics.
Workshop manual says to charge from the posts in the engine bay - I've attached a hard wired CTEK connector to the posts Thumbs Up
Post #558564 22nd Jun 2020 6:39am
