![]() | Home > Technical (L322) > Blower Fan Noise Issue |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
Just had my aircon blower fan replaced in December after the old one burnt out. Worked ok during the winter but I never tried it on max blower power as I normally only need this in the summer when I need to cool the interior quickly. In the winter I leave the blower on auto as it's usually enough to get the car warm reasonably quickly.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
To me that sounds like the fan is catching on something. They should fix that for zero charge! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35706 ![]() ![]() |
i wonder if a dead leaf has got in there somewhere....other than that it could be the fan bearings. ... - .- -.
I hope it isn't the bearings, the fan is a new unit. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Indeed, that is the case. The dealer took the fan out and tested it in isolation and discovered that one of the fan blades is broken and a loose part is hitting the casing when it rotates at full speed. They had another in stock and after testing that prior to installation they found out that it had the same flaw. So another has been ordered and they've also opened an issue with LR as it seems to be a faulty batch. Providing the new part doesn't suffer the same flaw it will be read by the middle of next week. Either way as it's a part failure it's being replaced at LR's cost. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
