![]() | Home > Technical (L322) > TDV8 turbo noise |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Presume no error messages or limp mode?
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 54 ![]() ![]() ![]() |
No, nothing at all. Will see what happens when I fit the hoses, and will check for other possible leaks. |
New upper intercooler pipes fitted but no change. Will check exhaust manifold. |
Not easy to even see the exhaust manifold. Check for missing studs/ nuts. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Mine makes a noise (when warm) best described as the VW air cooled engine. I suspect it’s a blowing exhaust but I’m told that the studs are intact. The ones we can see anyway.
https://rover.ebay.com/rover/0/0/0?mpre=ht...4039208033
Still making the noise but no codes or smoke. Cannot see any cracks. Will have to check studs. |
Well, I give up. It is booked into a local garage next week for them to have a look. |
Garage 1 reckons it could be the nearside turbo but won't do the job.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
That’s not ideal then. At least if you have a proper diagnosis, you can decide if you need to worry about it or not.... 2011 Range Rover Vogue SE 4.4 TDV8
Second garage said they don't know what it is and didn't seem to want to help.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2768 ![]() ![]() |
Time for a smoke test? |
Think so. Just need to find a garage with the kit. |
Not managed to get a smoke test yet. Just wondered if anyone had any other ideas as to what it might be? Hard to get it to a garage with current restrictions. |
