![]() | Home > Technical (L322) > Slow Water Leak |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Hey everyone, does anyone have any ideas on where a small water leak might be on a 5.0SC. I basically am loosing about 300ml every 4 weeks / 1000 miles. No signs of a leak anywhere, no error codes so don't think its an internal issue, guess it could be rad as its had to see the whole thing.
Water is normal anti freeze colour. I don't think there are any internal issues I think its just a small leak somewhere. |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
I had the same issue and it turned out to be the water (coolant) pump leaking. |
Thanks, will go have a closer look at the water pump |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1329 ![]() ![]() ![]() |
I've had the same amount of water going missing, and then the top hose was cavitating when the engine cooled. I know mine is the 4.4 tdv8, different than yours, but I've just put a new expansion cap on and the hose is now ok and no water loss yet. Worth trying at Β£6 for the cap. |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 37 ![]() ![]() |
Hi Lighthouse.
Hey Pete
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Mine is doing that as well. A camera showed it is the water pump and itβs leaking and leaving it in the V bottom. Still need to get it replaced π |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
I had a slight leak from my water pump on the old 4.4, intending to get it fixed. Then as I arrived at Meadowhall one day (80 miles from home) it went big style. Water was pouring out almost as quickly as I put it in.....
woodrjh Member Since: 13 Sep 2021 Location: Burgess Hill Posts: 26 ![]() ![]() ![]() |
So I've been chasing a coolant leak on my 2012 MY 5.0 S/C.
