![]() | Home > Technical (L322) > Judder Stutter Up Hill 3.6 TDV8 |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1844 ![]() ![]() |
Torque converter |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 936 ![]() ![]() ![]() |
the torque converter is not electrical, so does not throw up any faults on a scanner
Aaron9328 Member Since: 09 Oct 2018 Location: Wiltshire Posts: 3 ![]() ![]() ![]() |
Thank you for the reply both of you, Should a torque convert really be failing at such low mileage? Vehicle has never towed And has no tow bar fitted.On a straight flat bit of road the revs stay constant even with cruise control on 60-70mph revs stay around 1700-1800rpm no bouncing or fluctuating. |
well its 10 years old, I would get the TC seals changed first, and go from there |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Was it warm and with the AC on? This can give a surging sensation when accelerating slightly especially uphill. |
You do have a point there, age just deterioration of seals with age. I will have a chat with local transmission specialist see if they can keep it for a few days to test. |
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
Before you head down the gearbox out route to tackle the torque converter, it might be worth getting the prop shaft joints checked. Albeit on an earlier, petrol L322, I thought I had a failing torque converter. Had the gearbox refurbished and the vibration was still there. It turned out to be the prop shaft centre bearing (which Courtney on here suggested - ace forum member 👍).
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Check all the obvious mechanical joints first.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
How about a 'mega-flush' of the gearbox?
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1012 ![]() ![]() |
You mention that you have no DTCs present. Does that mean you have your own diagnostics kit, or did you get them read at a workshop? If it’s your own kit it would be worth checking to see if it’s capable of reading and recording live data, in particular the engine speed, turbine speed, transmission output speed and TC LUC solenoid current. If so, you could record these parameters during the vibration and analyse them (or I’d be happy to do it for you), which would tell you if it’s the torque converter lock-up clutch causing the issue. If not, it would allow you to eliminate it from your enquiries.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
*** doh, just saw you've already replaced the intercooler hoses - good luck sorting it! ***
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
It sounds like "cattle gridding'. RRPhil is the expert. I had this after my local indy changed the gearbox oil (2008 MY TDV8 116K miles at the time) shortly after I bought the car. No problems before that. Went back to them and they put in additive to sort it out. Now at 135K and it occasionally happens again, especially when the car has been driven for a while.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Bristol Transmissions get good feedback. Not too far from Wiltshire |
joncorry Member Since: 18 Dec 2018 Location: Warrington Posts: 89 ![]() ![]() ![]() |
Just resurrecting this thread as I suspect I may have TC issues. In this diagram, am I correct in reading there is a fault in this instance as there is juddering evident on the graph and the LUC doesn't 100% lock up? What was the end result for the original post? |
