![]() | Home > Maintenance & Mods (L322) > Rear arch rust repair help |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Black box is held on with some plastic barbs, you just have to be violent to get it off, or take the bumper off and do it from the outside...
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Thanks. What's the box for and called?
Por15 converts the rust it touches, the very outer layer, any rust that has penetrated a panel will have many layers and it will show its ugly head again...
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
I used Por15 and the 2nd stage ate all the rust back to shiny metal. Kept it wet for a good 20mins and got rid of it all and then painted with the 3rd stage.
Thanks both. I will get the wire brush attachment in there and have a go at cleaning it all up on the inside. Then get something on it to stop new rust forming from inside. Then I will attack the outside again as I'd done that last year but the odd spot is coming back through.
You should really tackle both sides at once. When I did mine, I found double skinning, foam insulation (soaked with water) etc. Best to get the bumper off and go at it with a wire brush tool on your drill so you can see the extent - it will be as bad under what may look like good paint. .
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
I agree, unless you cut out all the rust, no matter how much you treat the area and convert the rust, it is still seeded, it’s just a short term fix and will see blistering start under the paint within 18 months.
It was Dinitrol, IMHO Waxoyl has stood still over the years and been overtaken by lots of others... You can't hurt anything with overusing it so spread it about liberally... Any rusty metal left in place will rust no matter what you do to it, as ur20v agrees, cut it all out, if there is metal with rust that needs these so called rust converters then you have not cut enough out, buy a cheap mig welder, practice a bit and give it a go, it's not hard you just need a bit of experience... go on, have a go, do it properly and do it once......!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Thanks all. I agree after having done the outside once only for the orange to come back through was annoying to say the least.
Check out YouTube there’s loads of how to videos on how to make repair panels and welding etc
Thanks will give some a watch |
