Home > Technical (L322) > A/C and rear blowers auto starting.
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Hi all.
I've recently bought an L322, A 2010 3.6 SE at it is superb!
One question though, on starting the engine, the rear blower control on the drivers centre console and A/C auto start as well as the main auto temp control when you start the engine, even when stone cold.
I can't find reference to it in the handbook or any mention elsewhere on the net.
I'm sure it's very easily disabled but it is becoming annoying as it is unnecessary.
Anyone any ideas how to disable it?
Many thanks in advance.
G
Post #559230 27th Jun 2020 1:58pm
Dolphinboy
Ref the rear aircon switch, no you can’t do anything. It always comes in automatic and you have to wait 5 secs before manually switching it off.
The auto button: if you switch the aircon off before meaning the car, it should stay off whe you start up. At elast mine does!
Post #559261 27th Jun 2020 6:02pm
grey17
Hi Dolphinboy.
Thanks for that. I never use the A/C and it is switched off when I'm driving. There are no climate controls in use at all when the car is parked and switched off, but, on restarting, the A/C and rear blowers start up, the latter sounding like they are at full speed.
It doesn't seem quite right, like it's a preference set by the previous owner.
I've test driven plenty of them and not one displayed the same behaviour so I'm a little puzzled.
G
Post #559370 28th Jun 2020 1:04pm
Dolphinboy
Hhhmm not sure why that is. I would echo those with the knowledge on This forum who all recommend you have the aircon on at all times as it not only stops the seals drying out, but also removes water vapour from the air inside the car.
Post #559382 28th Jun 2020 2:04pm
Neilacker
Mine did this for years until I replaced the battery, after that it would remember the settings I left it on when switching car off, hope that helps 2010 tdv8 vogue se, Buckingham Blue
Post #559669 30th Jun 2020 8:13pm
mjdronfield
I’ve never turned my air con off after I got a £700 bill 20 years ago.... keeps the rubber seals lubricated and stops the windows steaming up.
I’m pretty sure mine stays off if I turn it off....
The rear.... that’s a different story and it always turns on when you start the car. I think mine has manual blower control in the rear though.... I don’t travel in there so not studied....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #559678 30th Jun 2020 8:36pm
DrRob
I keep the rear blower dial set to off.
Button on dash for rear ac has a mind of its own. Sometimes it stays off between start ups, sometimes it comes back Rolling Eyes Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #559679 30th Jun 2020 8:46pm
