![]() | Home > Technical (L405) > Meridian system help please |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
I was going to ask if it used all the speakers in a normal sound mode and whether you'd tried one of the surround / meridian settings. MY23 Panamera E-Hybrid
Wilpert Member Since: 22 Jun 2020 Location: London Posts: 103 ![]() ![]() ![]() |
Thanks Dave, I’m thinking it might be a loose wire or fuse. Do you know what number fuses are for the sound system? Where is the amp etc located, can I get to it to look at the connections? Thanks Craig |
I will check this out. Although the dealership said it had signature system on the build spec. The dealer I bought from is adamant that the roof speakers are only for driver and passenger communication. Now I’m confused. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
The Amp is under your passenger seat and would need your seat removing to check the connections sir... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
L5 & Signature confirm that it's the 1700W 29 speaker Meridian.
Ok update, I set my radio to a dab classical station and it was the first time that the front roof speakers played, the sound was awesome so crisp and clear. The rear seat speakers are still dead but I’m thinking they aren’t any part of the signature reference system? |
Rear seat speakers are very much part of the system
hmm,
ah, just saw that about menu options, no i havent checked this and TBH i dont really know how to but i will look into it. I have tried the fade and 3 d sound options, which i would have thought would cover this, i have even set the fade fully to the rear and no sound from these speakers? |
The rear entertainment system etc - I wouldn't rely on What HiFi to get it right
I have emailed "tech guy" at Meridian but I wont hold my breath for a reply.
Depends what you want to achieve......
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
if you're still concerned about your speakers Wilpert, take a look in the WM ..there are a couple of pdf's that explain the speaker system and how to diagnose problems. ... - .- -.
Thanks but don’t have a manual. Somebody decided to keep it. ☹️ |
