![]() | Home > Technical (L322) > Amber DPF Full - Increase in Oil Level |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I'd not worry about it too much if the Amber has now gone after a run. It was probably near it's limit when you had it idling on the drive and the run out cleared it. The owners manual states the recommended speed and duration needed to clear the amber. Revving the |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
John,
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Just to clarify, it’s the fuel/oil dilution Reading we are all talking about, not the engine oil level. If it is making your oil reading increase by that much I am surprised. Best get a fuel dilution reading on your new IID ASAP as it may point to something else causing it.
I'll also add that the oil level indicator is not always 100% accurate. When you take a reading make sure to leave it for 30 seconds to stabilise. Sometimes mine adds another notch after, sometimes it doesn't. Dipstick was best!
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
You definitely don't need sport mode or revs.
| 4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185
Many thanks to every one for your replies.
Lovely scenery |
| All times are GMT |
