Home > Technical (L322) > TD6 Auto oil change
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Update (just in case anyone else is thinking of doing this) - I couldn't find anyone who would do a flush (within 25 miles anyway), so I have ordered 20L of Texaco 7045E from Watsons Oil for £66 delivered and will be starting the "multiple oil change" technique this weekend !
I'm also going to try to siphon the oil into the gearbox by placing the 20L container on the passenger footwell and just use a bulldog clip on a length of plastic tubing at the gearbox end to control the flow ...
The gearbox does not appear to be exhibiting any nasty symptoms currently (touch wood), so I am hoping to prevent any in the next couple of thousand miles !
Post #55934 22nd Mar 2011 12:28pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Keep us updated on the how it went
Post #55970 22nd Mar 2011 3:31pm
That's a good price for ATF
Post #56007 22nd Mar 2011 6:55pm
VaguelyVogue
Done - and I was surprised at how easy it was.
After draining very black transmission oil into a bucket for about 30 minutes I got 6 litres out, with some sludge on the magnets in the pan. After going through each gear for 15s whilst stationary and running the engine to get the temperature up it took another two top ups to get to the right level at 43C. Since I was lacking any sophisticated workshop pumps, I just siphoned the ATF with the 20L container standing on a workmate at the side of the car.
Apart from burning my thumb when checking the levels after a 10 minute drive, the biggest surprise was how quiet and smooth the gearbox became ... I should have done this 10000 miles earlier ! Thanks to everyone for the advice.
Post #56824 26th Mar 2011 6:38pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Just got my filters today and ordered the same oil from Watsons so I will be doing mine next weekend.Fortunately I have the correct tool as I purchased it to change the oil in my TD5 Defender.Keeping my fingers crossed as the car has done 127k with no gearbox fault symptoms - yet ! Wink
Post #56829 26th Mar 2011 8:12pm
What is the correct tool?
Post #56876 26th Mar 2011 11:16pm
VaguelyVogue
A T45 Torx bit for the drain plug or a 17mm spanner for the fill plug - I found out at the last minute that my T40 was not the right size Rolling Eyes
Post #56893 27th Mar 2011 1:18am
mercs600
Draper 500ml Oil Suction Gun
Designed for use on vehicles and machinery such as gearboxes, axles, diff. engine etc.
Ideal for Gearbox/Diff refilling/top up on 4 x 4's
Supplied complete with flexible delivery tube 10mm bore, approx 12in - 30cm long.
All Metal Body and End Caps
Draper Stock No 47812 Part No A5/L
Ebay Number - eBay Item No. 130495757267
Very Happy
Post #57049 28th Mar 2011 9:01am
