Home > Technical (L322) > Nice lighting feature?
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Had an audi a6 recently and when you locked the car at night the driving lamps came on for a minute automatically. I'm aware that the q7 also did this and really liked it as a feature. I wonder if it would take much work to get this feature on a full fat?
They already have the light sensor fitted so surely can't be that hard? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #56058 22nd Mar 2011 11:05pm
Er they already do , when you park up push the light stalk forwards once you turn the engine of and your head lights will come on for a pre determined length of time. 2008 MY Supercharged
Post #56060 22nd Mar 2011 11:11pm
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
Standard feature on current model, also remotely controllable from keyfob Thumbs Up Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #56061 22nd Mar 2011 11:12pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Re: Nice lighting feature?
Yes the FFRR has this feature already is a custom option that you can have turned on or off, i have it turned on, on my car its called headlight delay and it works if the lights are on when you turn the car off the car leaves the lights on for around a minute and the car displays head light delay on the dash. This option is also called follow me home, you can also specify the time the lights stay on for. If you have a fault mate you can turn it on yourself, i used my faultmate to enable the feature if not you will need to visit a dealer.
Matt
Post #56062 22nd Mar 2011 11:13pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
yep, if my lights are on and I turn the igniton off before swithcing the lights off then they will stay on for a set period of time after I have locked the car. Thats a 2002 HSE model Smile FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #56066 22nd Mar 2011 11:22pm
pretlove
mine dont do this Big Cry or am i doing it wrong....all that happens is my side lights stay on Confused ...why we are on the subject of lights ,do i have auto lights as standerd i do have the xenon lights "RANGEISM WILL NOT BE TOLERATED"
Post #56075 23rd Mar 2011 1:46am
mattstevenson2005
Hi mate, you need to get the follow me home feature turned on to allow the main headlights to say on when you turn the engine off and turn the light switch off. On the pre 05 vehicles auto lights is not installed.... BUT you can installed it, in fact i am in the process of installing at the moment - to enable auto lights on a pre 05 range rover you need to change the LCM (Light Check Module) on pre 05 vehicles you have LCM 3 installed this will not do auto lights but you can swap LCM 3 with LCM 4 which supports auto lights. Then you need to replace the main light switch (below drivers vent) to the later one which has the extra auto lights position on the dial, and finally you need to replace the rain sensor (behind the rear view mirror, its the blue thing you can see from the outside of the car at the top of the wind screen) with the later rain AND light sensor. All these items are a straight swap and use the same connecitons e.g. plug and play. The only thing you may need to do is have the LCM 4 re-programmed to the options that are on your car e.g. xenon lights etc... you can use the LCM 4 from a BMW X5 E39 instead of one from a range rover as they are the same units.
Matt
Post #56084 23rd Mar 2011 9:00am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Matt - On the LCM subject - I'm doing this upgrade to my 54 Vogue at the moment. Had a look at my LCM and it say on it YWC500280 - 4B. The LR dealer can't confirm that this is the auto version so how can I tell? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #56089 23rd Mar 2011 9:39am
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
Anyone local to Aberdeen with a faultmate want to come round and switch mine on? Bow down
Post #56110 23rd Mar 2011 10:40am
mattstevenson2005
Hi mate, its easy to tell because the label will read LCM IV w/ auto lights. If it reads LCM III then you have the LCM 3 and you need LCM 4 (LCM IV)
Matt
Post #56186 23rd Mar 2011 3:11pm
pretlove
thanks matt Thumbs Up keep us posted on how you get on .....ill have to add this to the long list of things i want to do.....with facelift and nav at the top "RANGEISM WILL NOT BE TOLERATED"
Post #56196 23rd Mar 2011 4:15pm
hoppy_70
I get what your saying but..... Mine has the automatic headlights and I can make them come on by flashing once after the engines off.
It might sound anal but what I wanted was the driving lamps on both when I switch the ignition off and when I unlock the car, when it's dark. The driving lamps give a nice low spread of light that i'm after. Loved this feature on the Audi.
There must be a circuit that controls this because the puddle lamps in the mirrors activate at those very times. I'm not saying I could do it myself, just wondering whether it would be easy/ possible to set up. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #56251 23rd Mar 2011 6:54pm
mattstevenson2005
again these are features that can be activated with a faultmate or a trip to a dealer.
Matt
Post #56318 23rd Mar 2011 9:44pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Are rain sensitive wipers a standard feature on Vogues around 2003?
None of the ones I've seen had auto lights, but I didn't check re. wipers
Ps.... i can select this feature on my golf in a menu controlled by buttons on the steering wheel, i can even select how long for and have different settings for coming/leaving home. I'll miss german common sense when i finally get hold of a FF!
Post #56346 24th Mar 2011 1:07am
mattstevenson2005
Yes all L322 Range Rovers have auto wipers. You wont miss it for long after you get your FFRR, although the L322 was actually designed by a german company BMW.
Matt
Post #56359 24th Mar 2011 9:08am
