Home > Maintenance & Mods (L405) > Check oil level on MY 17 car
Page 2 of 3 <123>
@jumping mouse.....it does work, eventually....i sometimes have problems but i persevere and get a reading.. ... - .- -.
Post #560549 7th Jul 2020 9:07pm
1JBS
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I had the same problem with my 2015 SDV8 and ended up having a new sensor fitted under warranty, apparently it is a 10 hour job that Land Rover book time only allows 5 hours for !
Post #560626 8th Jul 2020 12:55pm
DrRob
My mechanic mate in Petersfield has just done on a L405. Not a nice job by all accounts Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #560655 8th Jul 2020 3:04pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I think I didn't follow the steps of having the engine hot and then waiting 15 minutes and being sure I'm on level ground. It's a lot easier with my son's Corsa.
I'll have another go when I nest use in a day or two.
Post #560679 8th Jul 2020 6:35pm
DrRob
Also let the reading stabilise for a few seconds when it does come up Thumbs Up
I check it cold in morning or 20mins after shut down of a hot engine Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560680 8th Jul 2020 6:39pm
jumpin mouse
There's a big development with this issue.
Landrover Assistance (AA) came out yesterday and confirmed that the oil level sensor was faulty and would need to be replaced. They arranged a hire car for me with Enterprise (F Pace) and Inchcape Preston now have the car. They have confirmed the diagnosis and got approval from Car Care to fix it under warranty, should be back on Tuesday.
However, ........
I realised that dropping the sump meant new oil and as the car is only 2 months from needing a service I asked if they would do the other service items and charge me for the service minus the oil and filter but they said, no, that's not possible. This means that if I ask them to service the car whilst they have it they will put new oil in and then drop it out immediately?? It all seems a bit bonkers and inflexible.
Does anyone know if they would normally fit a new oil filter when replacing the oil level; sensor?
Post #560962 11th Jul 2020 9:00am
jumpin mouse
All done, Inchcape replaced the sensor under warranty and I got the vehicle back this morning.
I can now check the oil level.
Post #561697 16th Jul 2020 1:10pm
you hope!
Wink ... - .- -.
Post #561700 16th Jul 2020 1:40pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #561702 16th Jul 2020 1:44pm
jumpin mouse
I can now, it showed something like "Oil level OK". A bit of an anti-climax really after all the hassle, I thought it might have been flashing or singing or something.
Post #561710 16th Jul 2020 2:26pm
'OK' is good..now for the trip.. Thumbs Up
edit..must be someone else going on a trip.. Embarassed ... - .- -.
Post #561713 16th Jul 2020 2:58pm
jumpin mouse
On Saturday we will take the ferry from Hull to Rotterdam and on Sunday we drive from Rotterdam to Gdansk, 13 hours plus stops and traffic. That's what triggered this whole oil level saga, I was being very diligent checking it a week before the trip but good that I did. At least it's perfect timing for an oil change.
Post #561714 16th Jul 2020 3:07pm
ah it was you..have a safe trip.. Thumbs Up ... - .- -.
Post #561716 16th Jul 2020 3:15pm
wealy
Is this a common fault? I think mine is playing up? Can it only be diagnosed with a plug in?
Post #564903 18th Aug 2020 2:34pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
It is becoming a more common fault. I've the same issue, though without the advantage of warranty to pay for the fix.
I've looked into doing the job myself and have bought the parts [sensor, wiring loom, clamp and sump gasket] which come to about £115. The issue is the 10-hours required to do the job. LR quote 7 hours, but I've heard that this is only because of the shock of the cost to change a simple sensor. The job is horrible and involves removing drive shafts, removing diff and dropping the sub-frame to get to the bolts on the sump. The sub-frame bolts can also have problems coming out due to corrosion and can break.
I've changed the oil and the level was correct [something like 7.2litres] so I don't believe I'm using oil, so it's not a top priority. Current options are:
- Change the sensor myself [can't face it at the moment]
- Pay someone to do it for me [I've had a quote for £650 including vat, plus the parts which I've already got]
- Developing a canister to hold the sensor at the side of the engine [difficult to work out the height required]
- Using piano wire [guitar wire isn't long enough] down the oil suction tube to act as a dipstick [yes, wire does go down there and around the bends]
- replacing the oil suction tube with a dipstick [just bought a used D3 dipstick for £20]
I will let the forum know when I've found a solution. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #564921 18th Aug 2020 5:17pm
Page 2 of 3 <123>
