![]() | Home > Technical (L322) > Internal voltmeter vs multimeter reading off battery |
More importantly, what does your meter read with as many electrical items turned on as possible? Blowers, lights, heated screens etc etc |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Thanks for responding. Yeah the voltages with a multimeter at the battery terminals reads 13.8/9v.with absolutely everything on it reads 12.6v...the dash voltmeter must be a cheap rubbish innacurate one as it shows 14.4v at startup with nothing switched on... |
Also... After 10mins or so the voltage at the battery reduces to 13.2v.. Is this because alternator senses it needn't pump as much voltage as it was doing earlier, or due to a fault? Curiously with the engine off, the voltage on the dash and the voltage measured at the battery match?? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
I would be inclined to check your battery connections. Are they both tight? iIf so try removing them and cleaning up both the posts and the internals of the clamps and refit. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
I never saw 14.5 on mine.
