Home > Technical (L322) > Strange thing happened the other day..
Andy
I unlocked the car using my wifes key and the drivers seat and mirrors adjusted themselves. I then used my key and the seat returned back to it's previous setting.
I checked the owners handbook and it is indeed a programmable feature. The reason why it's strange is because it's never done it before and it doesn't do it now! Unfortunately, it appears to be a one off and hasn't done it since Sad
Looks like an electrical glitch somewhere that needs addressing. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #5457 8th May 2009 11:04am
Andy
82 views and no-one knows why? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #5588 15th May 2009 5:24pm
Landrovered
United States 2003 Range Rover HSE 4.4 V8 Giverny Green
I have been trying to make this feature work on my 03 to no avail. 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5589 15th May 2009 5:26pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I have never figured out why and when and how this is suposed to work. Button 1 is my wifes setting button 2 is mine each set with our own key, trouble is the car seems to have turrets and dos random things for the hell of it. letters not necessarily in the right order
Post #5592 15th May 2009 7:07pm
Mine did it once in the last year and the rest of the time total altzhimers on the hole idea, mind you every time I ask the stealer to turn a programable function on they turn more off, I told you before shuldn't be allowed near sharp objects. Rolling with laughter 2008 MY Supercharged
Post #5599 16th May 2009 12:20am
Paul J.
Not sure about your MY, but with mine (and my D3 before that) you need to try the following:
1. Unlock car with your keys.
2. Set the seat, steering wheel and side mirrors to your position.
3. Store this as Memory 1 on the seat.
4. Lock the car with your key.
5. Unlock with SWMBO's key.
6. Move seat etc to her position.
7. Store this as Memory 1 on the seat.
8. Lock the car with SWMBO's key.
Now, when you unlock with your keys it should go to your seat/mirror position. When SWMBO uses her keys .... well, you can guess the rest.
(Each key has its own settings, which is why you can store two sets of seat memories)
Paul
Post #5611 16th May 2009 10:57pm
Dixy
7. Store this as Memory 2 on the seat.
Paul
EFA
Yep tried that, I recon the seats were made from the hides of catle with mad cow disease letters not necessarily in the right order
Post #5624 17th May 2009 5:40pm
Paul J.
Point 7 above should read Memory 1, as per my post. Wink
Each key stores Memory 1, 2, 3 separately, so with 2 keys you can store 6 seat positions.
Paul
Post #5625 17th May 2009 9:49pm
Dixy
If all else fails read the manual, I shal play with it today Bow down letters not necessarily in the right order
Post #5626 18th May 2009 8:08am
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Aha, thanks for that, I will try....
But more interesting, what means SWMBO ? XJC, RRV8, Series1 86 and 107% of real pleasure
Post #5627 18th May 2009 8:45am
SHMBO=she who must be obayed Thumbs Up 2008 MY Supercharged
Post #5628 18th May 2009 9:35am
I know what the manual states it SHOULD do etc but I've always had the impression the key takes the settings from the last time it was in use. That's why for example, the CD disc playing is different when I swap keys, it remembers what I was listening to last time on that key.
I've not done exhaustive tests on the memory thing, as SWMBO never drives my car, but we do have a seat memory setting for her all set up in case of emergencies so there is no faffing about. Discovery 4 HSE
Post #5635 18th May 2009 11:15am
