Home > Wheels & Tyres > Wheel alignment query, please advise
Bingo_123
Got the 4 wheel alignment done.
Doesn't look normal at OSR, the toe is negative
Tyre place guys said, it's not much and they are unable to adjust it.
As per them it won't make much difference and it might be due to bend in control arm etc.
Adding the chart below, please have a look and advise what can be done.
Thanks
Post #560991 11th Jul 2020 12:44pm
DrRob
I had similar. New links on both sides enabled adjustment and brought it all into the green. Parts were supplied by Advanced Factors and fitted by the garage who do the alignment for me Thumbs Up
Get it done. It will handle better and not scrub tyres Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #561017 11th Jul 2020 4:17pm
Bingo_123
Thanks DrRob, it's bad on one side, do I have to change links on that side only or both.
Also, will you be able to list the parts needed, that will be helpful.
Thanks
Post #561030 11th Jul 2020 5:54pm
DrRob
Do them both I would.
Call Advanced Factors and speak to Paul Redding Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #561035 11th Jul 2020 6:54pm
Bingo_123
Cheers, thanks
Post #561038 11th Jul 2020 7:09pm
Unless everything is completely seized, then they should be able to adjust it.
I do remember that many of the fast fit places have the 4 wheel machines but are reluctant to do anything more than toe..... There is nothing that can't be fixed with a hammer😜😜
Post #561042 11th Jul 2020 7:19pm
gettingold
Don’t those fast fit centres have the special Hunter machines?. Somebody on the RRS site got his adjusted for a fee and he could go back multiple times (I’ll try and find the post). It was refreshingly a good tale for this chain.
https://www.alignmycar.co.uk/
In lue of not being able to find the thread Hunt for a L405 is on.
Post #561099 12th Jul 2020 6:54am
Bingo_123
Thanks guys, sending the car to my indy on Wednesday, will ask them to have a look and sort it out.
Btw, what are permissible values for toe at rear. Is it too far out to cause premature tyre wear.
Post #561117 12th Jul 2020 11:05am
Yes a lot of the fast fit places now have a Hunter. The quickfit in Derby has one..... There is nothing that can't be fixed with a hammer😜😜
Post #561183 12th Jul 2020 9:17pm
Rob99
MarkinCW5 wrote:
Invest in large cans of WD40.
PlusGas is much more effective as a penetrating oil and release agent Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #561190 12th Jul 2020 10:27pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
From when we did mine earlier in the year.
Sort out camber before toe.
Your right rear needs to be a similar figure to your left rear ie -1.
Your toe should then get to 0 or just over positive but NOT negative.
Best L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #561204 13th Jul 2020 7:28am
Bingo_123
Thanks guys
Post #561221 13th Jul 2020 11:06am
