Home > Maintenance & Mods (L322) > Indicator Removal
csjxx
United Kingdom 2004 Range Rover Vogue 4.4 V8 Zermatt Silver
Indicator Removal
Hello,
Looks like my front drivers indicator bulb has gone, just wondering if i need to remove the headlight to gain access to remove the indicator?
Whats the easiest way?
Thanks alot
Post #56122 23rd Mar 2011 11:23am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
I find it difficult to scrabble around to change indicator or side light bulbs without removing the headlamp (which is very easy to remove):
- remove 3 screws at top of grill
- gently lift grill out, remembering the temperature sensor clipped to the lower part of grille
- 3 screws (from memory) to release headlamp unit
- change bulb at rear
assembly is the reverse of disassembly ...
A couple of minutes work to do this.
Post #56133 23rd Mar 2011 12:17pm
you dont have to remove the headlight....there are two large white butterfly type nuts holding the indicator unit , just unscrew and thats it... ... - .- -.
Post #56140 23rd Mar 2011 12:42pm
