Home > Technical (L322) > Engine system fault
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
Engine system fault
Just had the above message pop up and now power,switched off and started up again and seems ok but when I rev it up I get black ish smoke,iid tool has the following message
P023D-22 (6Cool Manifold absolute pressure - turbocharger/supercharger boost sensor A correlation - General signal failure - signal amplitude>maximum
Looks like turbocharger or inter cooler pipes?rang green flag to recover it home has I want to risk driving it,funny thing is voltage is only 13v when running.the egr valves were replaced about 2 years ago.its done 112000 miles and has been reliable in the 5 yrs I've owned it. Seems odd about the low voltage . 2009 Vogue SE Zermatt silver
Post #559801 1st Jul 2020 6:46pm
kbald
I don't think it's the voltage and it's a bit low but depends how much stuff you have on.
Best guess would be upper hoses on top of the engine (easy to remove and check) or cracked inlet manifold probably right hand side.
I'd start with the hoses first Current 2007 TDV8 Vogue Buckingham Blue
Post #559814 1st Jul 2020 7:31pm
kbald
In fact checked back and this is the code and exact symptoms I had with the cracked manifold. Diagnosed mine with some soapy water on it to see it bubble. Hopefully it's just the top hoses for you though Thumbs Up Current 2007 TDV8 Vogue Buckingham Blue
Post #559816 1st Jul 2020 7:35pm
mrtidy
I thought the hoses but I have changed them but it was about 4yrs ago .a quick visual check and they look fine,my voltage has always been 14.5 volts or there abouts,but concerned about the smoke really. 2009 Vogue SE Zermatt silver
Post #559818 1st Jul 2020 7:37pm
mrtidy
Cracked manifold would be cheaper than new turbos though. Every cloud lol Very Happy 2009 Vogue SE Zermatt silver
Post #559820 1st Jul 2020 7:38pm
kbald
It will be cheaper than turbos and is fairly common. Get some soapy water in a spray bottle take the top cover off and spray it on the plastic manifold with the engine on and maybe so done gently raving and look for bubbles. Start with the right hand one (drivers side) first I'd say.
New manifold is about £350 then fitting if you don't do it yourself. I was quoted 8 hours labour to do it so did it myself. Fiddly is an understatement with the hidden bolts and injector leakoff pipe clips Current 2007 TDV8 Vogue Buckingham Blue
Post #559822 1st Jul 2020 8:00pm
mrtidy
Thanks for that kbald I'll have a look tomorrow and see what's what. Might have to use my local indy landranger services for the manifold or turbos.its been relatively trouble free for the past 5 yrs so can't complain too much. 2009 Vogue SE Zermatt silver
Post #559823 1st Jul 2020 8:26pm
diesel Dave
England 2015 Range Rover Autobiography SDV8 Loire Blue
Make sure you check the hoses thoroughly, the right one as you look at the engine cracks under the webbing and you can’t see it until removed. 4 years depending on mileage would be about right for them to fail again, I only got 3 years but did do a lot of towing.
Post #559854 1st Jul 2020 10:33pm
mrtidy
Thanks diesel dave,I'll have a look tomorrow. 2009 Vogue SE Zermatt silver
Post #559858 2nd Jul 2020 12:07am
mrtidy
Pulled the top intercooler pipes off and found a 1inch split in the pipe with the webbing on it,ordered 2 new ones which will be here in the morning.
Result.. 2009 Vogue SE Zermatt silver
Post #559927 2nd Jul 2020 2:29pm
kbald
That's worked out well. Much cheaper than a manifold or turbos Current 2007 TDV8 Vogue Buckingham Blue
Post #559996 2nd Jul 2020 8:20pm
mrtidy
Have to say it's made my day...I'll fit the new hoses tomorrow then fingers crossed all will be well Very Happy 2009 Vogue SE Zermatt silver
Post #559997 2nd Jul 2020 8:24pm
diesel Dave
Fantastic to hear, hope all is ok now Thumbs Up
Post #560095 3rd Jul 2020 2:42pm
mrtidy
All is well now thanks,new hoses fitted fault codes cleared and just been on a quick run and car feels perfect again. Thumbs Up 2009 Vogue SE Zermatt silver
Post #560096 3rd Jul 2020 2:46pm
mrtidy
Just a quick update about my new turbo hoses,they have been fitted a week now so i pulled them off to see what they were like inside after a weeks running,the left hand one looking from the front does have a film of oil on the inside of the hose,is this normal do you think?while the right hand one is dry(the right hand one is the hose that had the split)my egr valves were replaced 20000 miles ago and they are working fine so i was thinking of doing the egr blank and the thought behind this is it should help avoid turbo problems in the future. Anyone agree or not? 2009 Vogue SE Zermatt silver
Post #561265 13th Jul 2020 4:22pm
