![]() | Home > Maintenance & Mods (L322) > Solar battery charger |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 541 ![]() ![]() ![]() |
I've been considering it for my camper. Depending on your needs, an 80W panel gives you 5+ Amps on a decent day for most of the day. Let's say 40Ah which is not too bad. That could go a long way to keeping the battery charged.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Living in West Australia most of my camping is done in remote areas totally off-grid so a solar charge system is pretty much a requirement. The simple solution is to get a folding panel with a charge controller like this https://www.ebay.co.uk/itm/100W-Portable-M...Sw3bZcOMwx Fitting a second battery in the rear with a charge isolation relay is the next step. We are lucky here that used household solar panels can be picked up for A$20 which linked to a decent MPPT charge controller can keep you in power indefinitely
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Go camping to a site with electrical hook up.
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
Thanks for your replies - seems as though a hook-up will keep SWMBO happy! 👍 L322 TDV8 4.4 - current
I had to do the same. Hook up saved the day |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3839 ![]() ![]() ![]() |
JLR will wake up one day and realise the potential of the glass panel in the roof.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
That's about a tenner each in GBP. Whats the reason for them being de-commissioned ? Is it because their efficiency has dropped off ? 2003 Range Rover Vogue TD6 |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
Audi used to have that option on the A8, but all it could do was power a small fan and I think the Prius has/had it as an option as well. The problem is that even if you leave it all day, it won't generate a huge amount of power, but agree that it's a missed opportunity. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
Brian Considine
^ Very impressive, unfortunately solar doesn't work in rain. |
It does work in rain and cloud but obviously not as well, It does not work in the dark. 2007 TDV8 VSE
Thanks for explaining the situation in Australia.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1575 ![]() ![]() |
I have what is supposed to be a 160w folding solar panel for camping. I doubt the rating. On a sunny day (most days) the max I get out of my panels is about 7.5A - that's with a PWM controller - into my 2 x 45AH deep cycle AGM batteries in the RH rear corner (bigger batteries won't fit).
