Home > General > window left open - locking car?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
might be me not understanding something - not unusual!
but if you leave a window/sunroof open and then lock the car i expect the said window/sunroof to close automatically
have i got something wrong?
and if someone says its an 'option' to be switched on the a main dealer i'll throw something Rolling with laughter
Post #56142 23rd Mar 2011 11:45am
Fox
You need to hold the lock button, then the windows and sunroof will close.
Post #56143 23rd Mar 2011 11:47am
nick h
thank you Thumbs Up
Post #56145 23rd Mar 2011 11:48am
Fox
You can do the same in reverse.
On a hot day hold the unlock button and they open. Thumbs Up
Post #56146 23rd Mar 2011 11:49am
nick h
gets even better - thank you Thumbs Up
thats what is great about this forum - people helping others - well done
Post #56147 23rd Mar 2011 11:51am
Re: window left open - locking car?
I was sorely tempted! Whistle
Post #56153 23rd Mar 2011 12:24pm
nick h
well, the solution kindly offered by Mr Fox does not work on my car Mad
so i guess its another 'thing' that needs to be 'switched on' by main stealers
my patience is starting to run very short with LR/RR today Evil or Very Mad
Post #56202 23rd Mar 2011 3:27pm
Fox
Have you pushed the button to lock/unlock and then pushed the same button again and held it down for several seconds?
If so... you're screwed. Consult your dealer. Sad
Post #56204 23rd Mar 2011 3:34pm
+1
Post #56205 23rd Mar 2011 3:34pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Don't you also have to be pointing the key at the drivers door lock? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #56208 23rd Mar 2011 3:54pm
dan_uk_1984
Please don't take this the wrong way - but this really is covered comprehensively in the manual...
Post #56212 23rd Mar 2011 4:09pm
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I have a possible answer here for you guys.
All the windows need to work in the "one touch" mode to allow this option to work, i.e. you push the button to wind down and let go and the window still goes to the bottom as opposed to having to hold the button down till the window gets to the bottom.
To make this happen, hold the button down till the window goes all the way to the bottom and release the button, then repeat the process to wind up and release the button - then hold the button up for 2 - 3 seconds.
Once done try to wind the window down, if you push the button down fully and release and the window continues going down then that window is ok - repeat for all other windows.
This should switch on the "all open/close option". With the windows open, push the lock button and keep pressed pointing the fob towards the vehicle, after a few seconds the windows should close etc.
Hope this helps chaps. "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #56267 23rd Mar 2011 6:29pm
daveo
if you push all three buttons and shake it at the same time your car changes colour... V8 facelift Range Rover Autobiography 22" wheels.
Post #56332 23rd Mar 2011 10:14pm
Japseroony
Really good advice and very helpfull Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
Post #56334 23rd Mar 2011 10:26pm
Rolling with laughter ..... ... - .- -.
Post #56352 24th Mar 2011 7:39am
